Scott TMN Posted March 18, 2013 Share Posted March 18, 2013 Ok so as my zed only came with the one key, i think its probably a good idea to get myself a spare, just incase of an emergancy of me losing the main. Now i understand they need to have the remote, or the alarm will just off go? So what is the cheapest way of going abaout getting my emergency back up, is it a stealership jobby, or can you buy blanks cheap and programe them yourself? Cheers, Scott Quote Link to comment Share on other sites More sharing options...
ir655 Posted March 18, 2013 Share Posted March 18, 2013 Hey Scott, I believe you can buy a spare remote from eGay and program it doing some sort of rain-dance with the key/pedals/door something etc. Do a search and see if you find the specifics of programing the remote. Make sure you buy a remote with the electronic internals if going the eGay route! Some of them are just the shell. Good luck! Quote Link to comment Share on other sites More sharing options...
Ebized Posted March 18, 2013 Share Posted March 18, 2013 http://www.350z-uk.com/index.php?showtopic=16896 Quote Link to comment Share on other sites More sharing options...
KyleR Posted March 18, 2013 Share Posted March 18, 2013 The rain dance and link that Ebized has posted it to program the remote functionof the keyfob, it still won't start the car as far as I am aware, for that you have to go to a decent locksmith or your nissan dealer for them to bum rape you for programming it. I believe the going rate for getting a new key and programmed in Nissan is Circa £160, ouch. Quote Link to comment Share on other sites More sharing options...
Scott TMN Posted March 18, 2013 Author Share Posted March 18, 2013 ok thanks for the replies guys. searched the bay, and found this http://www.ebay.co.uk/itm/GENUINE-NISSAN-350-Z-REMOTE-KEY-NEW-KEY-BLADE-MODEL-/111027580399?pt=UK_Car_Accessories_Safety_Security&hash=item19d9c26def So like above, i could get this, then take it to a locksmith, then try the rain dance to program it myself, if that fails, worst comes to the worst ill let nissan programm it, but still has to be cheaper as they are only programming surly? Quote Link to comment Share on other sites More sharing options...
HARMLU Posted March 18, 2013 Share Posted March 18, 2013 should be ok, the earlier keys have a transponder chip separate but I am guessing this is the later key which has it built in to the micro chip. The pedal dance will program the key and you will obviously need to get the blade cut so you can turn the barrel! Quote Link to comment Share on other sites More sharing options...
KyleR Posted March 19, 2013 Share Posted March 19, 2013 Locksmith can program it for you, might be a little cheaper than Nissan. Quote Link to comment Share on other sites More sharing options...
Scott TMN Posted March 19, 2013 Author Share Posted March 19, 2013 Okay cheers for your help guys, ill give this a go Quote Link to comment Share on other sites More sharing options...
