stuey Posted April 24, 2007 Share Posted April 24, 2007 this may be coinsidance but since i put the 20" wheels on when i do a bit of speedy cornering the slip light comes up and cuts me power....... except that my traction is 100% still there and defo not silding..... this seems to happen more often than not...................... any ideas.........?? Quote Link to comment Share on other sites More sharing options...
lomoto Posted April 24, 2007 Share Posted April 24, 2007 quite usual, switch the TCS off , I always do Quote Link to comment Share on other sites More sharing options...
stuey Posted April 24, 2007 Author Share Posted April 24, 2007 shall i try the ecu reset proceedure Quote Link to comment Share on other sites More sharing options...
lomoto Posted April 24, 2007 Share Posted April 24, 2007 shall i try the ecu reset proceedure Why not cant hurt , but I think you'll find it will still cut in Quote Link to comment Share on other sites More sharing options...
stuey Posted April 24, 2007 Author Share Posted April 24, 2007 do you think its anything to do with the wheel rotation speed in relation to the gearbox speed......???????? Quote Link to comment Share on other sites More sharing options...
lomoto Posted April 24, 2007 Share Posted April 24, 2007 do you think its anything to do with the wheel rotation speed in relation to the gearbox speed......???????? what size tyres have you got on ?? Quote Link to comment Share on other sites More sharing options...
stuey Posted April 24, 2007 Author Share Posted April 24, 2007 275/30/20 on the back.......... 245/35/20 on the front Quote Link to comment Share on other sites More sharing options...
lomoto Posted April 24, 2007 Share Posted April 24, 2007 275/30/20 on the back.......... 245/35/20 on the front thats why its slipping different profile tyres front top back just switch off traction Quote Link to comment Share on other sites More sharing options...
stuey Posted April 24, 2007 Author Share Posted April 24, 2007 differant profile but the same rollong radius......!! ok i tried the ecu reset proceedur and dissconnecting the battery........... will keep u posted on any developments.............. Quote Link to comment Share on other sites More sharing options...
lomoto Posted April 24, 2007 Share Posted April 24, 2007 differant profile but the same rollong radius......!! but not same differential as standard set up Quote Link to comment Share on other sites More sharing options...
stuey Posted April 24, 2007 Author Share Posted April 24, 2007 oh. i see......!! Quote Link to comment Share on other sites More sharing options...
t3dcf Posted April 26, 2007 Share Posted April 26, 2007 I changed my rims too and had the same problem, its to do with the tyre size and ratios etc.... I had to change my tyre size so that is sorted it - search for my posts and you should find what i did! good luck Quote Link to comment Share on other sites More sharing options...
stuey Posted April 27, 2007 Author Share Posted April 27, 2007 i tried all the rest proceedures......... still the same........ any more suggestions...!! Quote Link to comment Share on other sites More sharing options...
Guest prescience Posted April 27, 2007 Share Posted April 27, 2007 differant profile but the same rollong radius......!! but not same differential as standard set up Not sure what you mean by that mate? Quote Link to comment Share on other sites More sharing options...
lomoto Posted April 27, 2007 Share Posted April 27, 2007 differant profile but the same rollong radius......!! but not same differential as standard set up Not sure what you mean by that mate? standard sizes are 245/45 and 225/45 so rolling radius's arnt the same Stuey has exactly same rolling radius front / rear ..so I'm guessing that is the probs Quote Link to comment Share on other sites More sharing options...
Removed Posted April 27, 2007 Share Posted April 27, 2007 to confuse things further.... when i first put on my alloys (18" but wider, much wider than stock) all was ok, never had any issue of TCS and ABS kicking in prematurely, whereas now that I changed rear tyres (and not fronts) I get the TCS to kick in when not needed, mostly on fast left hand bends. Quote Link to comment Share on other sites More sharing options...
stuey Posted April 27, 2007 Author Share Posted April 27, 2007 to confuse things further.... when i first put on my alloys (18" but wider, much wider than stock) all was ok, never had any issue of TCS and ABS kicking in prematurely, whereas now that I changed rear tyres (and not fronts) I get the TCS to kick in when not needed, mostly on fast left hand bends. same here.......... mine is left or rights but not all the time........ is there anything you can do to re train the managemet system......?? Quote Link to comment Share on other sites More sharing options...
lomoto Posted April 27, 2007 Share Posted April 27, 2007 to confuse things further.... when i first put on my alloys (18" but wider, much wider than stock) all was ok, never had any issue of TCS and ABS kicking in prematurely, whereas now that I changed rear tyres (and not fronts) I get the TCS to kick in when not needed, mostly on fast left hand bends. same here.......... mine is left or rights but not all the time........ is there anything you can do to re train the managemet system......?? try this..... http://www.350z-uk.com/forum/viewtopic.php?t=4521 Quote Link to comment Share on other sites More sharing options...
Guest prescience Posted April 27, 2007 Share Posted April 27, 2007 to confuse things further.... when i first put on my alloys (18" but wider, much wider than stock) all was ok, never had any issue of TCS and ABS kicking in prematurely, whereas now that I changed rear tyres (and not fronts) I get the TCS to kick in when not needed, mostly on fast left hand bends. Interestingly (and I had no idea until I did a spreadsheet calc. just now) a tread difference of 7mm (I know that's at the extreme) makes a 2.2% difference in rolling radius and circumference. This is significant and might explain why changing one wheel from a very low tread to new would affect the slip Quote Link to comment Share on other sites More sharing options...
Removed Posted April 27, 2007 Share Posted April 27, 2007 to confuse things further.... when i first put on my alloys (18" but wider, much wider than stock) all was ok, never had any issue of TCS and ABS kicking in prematurely, whereas now that I changed rear tyres (and not fronts) I get the TCS to kick in when not needed, mostly on fast left hand bends. Interestingly (and I had no idea until I did a spreadsheet calc. just now) a tread difference of 7mm (I know that's at the extreme) makes a 2.2% difference in rolling radius and circumference. This is significant and might explain why changing one wheel from a very low tread to new would affect the slip you know what, that was the only thing I could think of too. fronts will be say half way ~4mm and rears are new (say ~8mm) and that was THE only difference since the tyres are exactly the same as before. ah well, empty car park here I come (will have to re-establish tread depth front-back symmetry somehow! ) Quote Link to comment Share on other sites More sharing options...
350Znismo Posted May 2, 2007 Share Posted May 2, 2007 I have the same problem with my 20" wheels, i just turned it off Quote Link to comment Share on other sites More sharing options...
stuey Posted May 2, 2007 Author Share Posted May 2, 2007 to confuse things further.... when i first put on my alloys (18" but wider, much wider than stock) all was ok, never had any issue of TCS and ABS kicking in prematurely, whereas now that I changed rear tyres (and not fronts) I get the TCS to kick in when not needed, mostly on fast left hand bends. same here.......... mine is left or rights but not all the time........ is there anything you can do to re train the managemet system......?? try this..... http://www.350z-uk.com/forum/viewtopic.php?t=4521 has anyone tried this vdc recalibrate proceedure???????? Quote Link to comment Share on other sites More sharing options...
Removed Posted May 2, 2007 Share Posted May 2, 2007 nope can't b arsed pushing my car, go on you try it and let us know Quote Link to comment Share on other sites More sharing options...
stuey Posted May 7, 2007 Author Share Posted May 7, 2007 ok. ive tried the reset proceedure so now i will let you know as to the results........ Quote Link to comment Share on other sites More sharing options...
M13KYF Posted May 8, 2007 Share Posted May 8, 2007 ok. ive tried the reset proceedure so now i will let you know as to the results........ nice one, it would be good to know if it's true or not Quote Link to comment Share on other sites More sharing options...
