Quick question - drop links
KyleR
Hi very quick one, I just stuffed up the thread in my N/S/F droplink so I can't get the nut back on, is it safe to remove the droplink completely and still drive until I get a new one?
Kyle
Edited by KyleR
Define safe :scare:
Yes the car will still drive - no you won't damage anything BUT you are disconnecting the ARB from side to side which will affect the handling, so I would suggest you drive slowly and carefully if you have to drive. It will mess with the cornering the most.
So can you drive without it - yes
Should you - IMHO NO!
As what Keyser has said:
Plenty drop links and nuts in stock Kyle, and good to go same/next day.
Alex. :)
Thanks Alex :thumbs:
I'm gonna get a guy to try repair the first 2mm of thread or whack it off as there's about 5-6mm spare when the nuts on tomorrow, if that doesn't work ill give you a shout tomorrow night ;)
I managed to grind off the first 2 threads and source a new nut from the floor of a mechanics :lol: so for now luckily I don't need new drop links, although I know I will in the not too distant future and I know where to get them ;)
