DaddyCee Posted March 7, 2013 Share Posted March 7, 2013 (edited) All. I seem to have a clunk from the front passenger wheel when I hit potholes or some uneven surfaces. The bushes were both changed last July / August time (thanks ZMANALEX). I am wondering if it could be worn out already or if the suspension just needs a good lube. What would be my best point of action? I have an MOT next month so could wait till its up on the ramp to inspect it properly. Are there any other causes I should be wary of? It's a 2007 Roadster with 55K on the clock. Cheers, DC. Edited March 7, 2013 by DaddyCee Quote Link to comment Share on other sites More sharing options...
Keyser Posted March 7, 2013 Share Posted March 7, 2013 (edited) Which bushes did you change? or all of them? Could be bottom suspension bushes, banana arm bushes or drop links - unless you changed all of them?? Edited March 7, 2013 by Keyser Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted March 7, 2013 Share Posted March 7, 2013 Simples, get the car checked out properly for an informed diagnoses. Hopefully it will nof be to serious or expensive. I will have any parts that you may require in stock and good to go same/next day. In the meantime best to check your wheel nuts are tight. Alex. 1 Quote Link to comment Share on other sites More sharing options...
DaddyCee Posted March 7, 2013 Author Share Posted March 7, 2013 changed the banana arm bushes last year. Quote Link to comment Share on other sites More sharing options...
DaddyCee Posted March 7, 2013 Author Share Posted March 7, 2013 Simples, get the car checked out properly for an informed diagnoses. Hopefully it will nof be to serious or expensive. I will have any parts that you may require in stock and good to go same/next day. In the meantime best to check your wheel nuts are tight. Alex. Thanks there. You never know who to trust with your ZED even specialists seems to mess up. Quote Link to comment Share on other sites More sharing options...
The Trouser Posted March 7, 2013 Share Posted March 7, 2013 I had a rattling sound from my drivers-side front wheel for months when ever I hit a pot hole or went over a speed bump. It sounded as if a plywood board had been loosely tied to the underside of the car and rattled when the wheel hit something. My previous Nissan dealer couldn't find the problem and suggested swapping out parts until the noise disappeared - I never went back My new Nissan dealer found the problem straight away - the front suspension arm. Apparently Nissan had a bad batch of 'em. This is on an 04 plate 350Z HTH Quote Link to comment Share on other sites More sharing options...
samsniss350z Posted March 8, 2013 Share Posted March 8, 2013 The Trouser has just taken the words right out of my mouth. Quote Link to comment Share on other sites More sharing options...
