Feeding wires through centre cubby hole - question
z350convert
Hi.
Want to put Mobile phone sat nav and camera alert in the cubby hole and wire to speakers. No problem with that but without dismantling the centre console assembly which is a bit of a sledgehammer to crack a nut, does anyone know best way to feed power from the front cig lighter socket and thin cable from tape deck up behind and into the centre cubby hole.
Thanks and in eager anticipation!
Neil
I fitted a speed camera detector in the cubby a couple of years ago. From memory I removed the cubby false base and drilled a hole in the LHS back corner. I then pushed a long length of single core white wire down the hole and fished it out of the passenger side foot well. I then attached the wires I wanted to pull in to the white wire and pulled them throgh.
Hope that helps or gives you a better idea!
