Tiny bit of Rust
Toad
Hi all I'm a complete novice with anything to do with cars - I've got a tiny rust spot only 4mm x 4mm on the rim of the back side window - is this something I can repair myself and if so can someone advise on the products I need to get and what I need to do - car is gun metal
Thanks and sorry for the beginners question
I did a repair like this on my E36. If you have the time a skill to rub it down and treat it, spray it then you can do it.
Personally I would hand it to a good bodyshop for the cost wouldn't be much and it will probably be a better job :p
I think this is one of the pictures from his post...
Seriously though, try http://www.350z-uk.com/topic/64678-how-to-treat-this-small-chip-which-has-a-small-bit-of-rust-on-it/
lol
i thought grinding it all off would be a good idea :D
seriously though like leonk said I had pretty much the same issue. small chip just around the edge of the rear passenger side window.
simply used a glass fibre pen to get the rust off, added some krust then just to make sure there was nothing else left. then used some etch primer with a toothpick to get an undercoat and once properly dried used the standard nissan touch up kit.
came out really well I thought.
If you've got anymore questions just drop me a line. was first time I'd done anything like this and it went well so I wouldn't worry to much. Most importantly I'd say be patient when your doing the work. dont rush it. A bit of good weather helps as well
