Bullet Posted March 1, 2013 Share Posted March 1, 2013 I've just bought a new set of wheels and tyres after lots of research i went with 18x 8.75 20et with 265/35/18 on the front and 18x 9.75 20et with 285/35/18 on the rear. I was looking for a flush look and have seen this set used quite a lot in the states but for some reason my back wheels are sticking out of the arches by about 15mm. anyone on here running that set up ? has anyone got any advice on where i go from here. Quote Link to comment Share on other sites More sharing options...
AliveBoy Posted March 1, 2013 Share Posted March 1, 2013 Do the people in the US flare/pull the arches out? Do they use the same tyre size too? As it could be they have some stretch on the tyre to bring the tread under the arch. Quote Link to comment Share on other sites More sharing options...
370Ad Posted March 1, 2013 Share Posted March 1, 2013 This is mine with 10.5 J ET20 on the back. Running 275 width tyres so slightly stretched. Obviously your tyre would stick out another 5mm each side but the wheel in theory should be further in the arch. Have you got any photos as it shouldnt stick out further than the arch. Quote Link to comment Share on other sites More sharing options...
docwra Posted March 1, 2013 Share Posted March 1, 2013 If the wheel is sticking out the arch ........ your wheels arent 9.75 ET20. This is 10J ET20 ........ IIRC that was a 255 tyre, a 285 will be a bit wider but not that much Quote Link to comment Share on other sites More sharing options...
S1 HNK Posted March 1, 2013 Share Posted March 1, 2013 +1, that set up sounds fine so I can only assume the wheels you have aren't what you've been told. You checked to see if your current hubs have spacers fitted? May have been on from the previous owner if you bought the car used? Worth a look. Quote Link to comment Share on other sites More sharing options...
4RE Leather Posted March 1, 2013 Share Posted March 1, 2013 On 01/03/2013 at 13:07, S1 HNK said: +1, that set up sounds fine so I can only assume the wheels you have aren't what you've been told. You checked to see if your current hubs have spacers fitted? May have been on from the previous owner if you bought the car used? Worth a look. +1 Quote Link to comment Share on other sites More sharing options...
Bullet Posted March 1, 2013 Author Share Posted March 1, 2013 I've double checked the width and offset and they are all fine and there are no spacers on the car The only other thing i noticed that you guys seem to have lowered cars, could it be that you have more camber ? i'm baffled Quote Link to comment Share on other sites More sharing options...
smudgedon Posted March 1, 2013 Share Posted March 1, 2013 They can't be ET20 Quote Link to comment Share on other sites More sharing options...
S1 HNK Posted March 1, 2013 Share Posted March 1, 2013 It could just be camber. I'd say 285 tyres are on the limit of how wide you can go but plenty of people run a 9" front, 10" rear et20 without lowering and it doesn't stick out that far. That's the limit of my technical knowledge, someone will be able to help but I'm baffled! Quote Link to comment Share on other sites More sharing options...
KyleR Posted March 1, 2013 Share Posted March 1, 2013 What's the fronts look like? I've got 10.5 et 20 and they don't stick out that much, I did how try on an 18x10 et 24 Blitz alloy last year and it stuck out nearly an inch despite being thinner and a higher offset than my rotas Quote Link to comment Share on other sites More sharing options...
Bullet Posted March 1, 2013 Author Share Posted March 1, 2013 The fronts are fine, they are pretty much completely flush this is that car i took inspiration from and its running a wider wheel with a lower offset and the same size tyres :S The way i see it ive either got to lower it and run enough camber for it to sit inside the arch which will probably ruin the tyres or pull the rear arches Quote Link to comment Share on other sites More sharing options...
docwra Posted March 3, 2013 Share Posted March 3, 2013 That pic I put up there is on standard suspension, and is definitely 10 ET20, I dont think youve got the right wheels. That said the fitment youve got looks fine to my eye, it not a big problem is it?? If you really dont want any protrusion from the arch a degree of camber would fix it, they look pretty right to my eye already though Quote Link to comment Share on other sites More sharing options...
