Veilside Posted April 19, 2007 Share Posted April 19, 2007 Hi, I know what eveyone says you can't put a Bose system in a none Bose Z well I have a complete Bose system with the matching Bose loom (seperated from the main loom). The Bose system came out of a UK 2006 Z with sat nav and if I get brave enough will go into 2003 Jap Z none sat nav. The only bit i'm not sure of, I'm hoping someone will know the answer is plug M39 (plugs into the head unit) pin numbers from 18 to 32 which pins correspond to the steering wheel contols for the Bose volume and channel change. My 350Z workshop CD audio section doesn't give all the pin information, apparently this info is on the dealers ESM disc. Is there any other problems I've overlooked is it worth the trouble ? Quote Link to comment Share on other sites More sharing options...
