Blackberry Gateway
jamesyj
I've been doing a little thinking...
The blackberry music gateway is a device that connects via BT to your phone, the device plugs in to a normal 3.5mm aux in. You stream your music over BT to it.
http://www.play.com/Mobiles/Mobile/4-/40686657/741210711/BlackBerry-UK-ACC-41596-002-Music-Gateway/ListingDetails.html?_%24ja=tsid:11518%7Ccat:40686657%7Cprd:40686657
I'm thinking of adding this to the Bose hack (haven't got around to doing this yet though) then having a blackberry music gateway in the cubby. They're quite small (zippo sized).
I get in my car, tap my nfc phone on the gateway, select 'tape' on my bose and carry on. You'd have to hard wire it which could prove difficult for me but will probably pose no problem for the masses.
I hate cables BTW.
Theoretically phone should be fine having two separate BT connections and on the reviews I've read, it should stop playing music when someone calls and then the 350z would take the call.
Not bad for £30.
