skidder Posted February 25, 2013 Share Posted February 25, 2013 Hi all, I've posted before but not much luck as i'm not technically minded. I have a black GT4 that has headlights that are misty/smeared inside.I bought it like this.(I got a small discount)There is NO water or condensation entering the light now.I have no idea how this has happened but it's really detracting from the cars looks and is really starting to annoy me.I don't see how the smears etc have got in there unless the units have been de-assembled before.I doubt this to be honest as there is definitely no leak. I realise that the only way is to remove the headlights and put them in the oven/heat gun and clean and then re-seal or replace altogether.I don't feel comfortable doing this myself. I don't really see the point in replacing the headlights at around 800 quid plus labour(used) as there is nothing else wrong. Is anyone willing to do this work for me?I'm in oxford and am willing to travel 60+ miles each way to get this sorted.Maybe even more. Much appreciated, Chris Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted February 25, 2013 Share Posted February 25, 2013 How do you know it's on the inside ... have you tried polishing the outside ? Quote Link to comment Share on other sites More sharing options...
skidder Posted February 25, 2013 Author Share Posted February 25, 2013 Yes i've tried polishing the outside.Its definitely on the inside.I've seen several zeds with this problem.Sometimes only one light. Quote Link to comment Share on other sites More sharing options...
peteman35 Posted February 25, 2013 Share Posted February 25, 2013 you doubley tripley sure? i thought mine were like that until i gave them a really good polish and it was on the outside 1 Quote Link to comment Share on other sites More sharing options...
skidder Posted February 25, 2013 Author Share Posted February 25, 2013 (edited) you doubley tripley sure? quadropley sure! Edited February 25, 2013 by skidder Quote Link to comment Share on other sites More sharing options...
catamahu Posted February 25, 2013 Share Posted February 25, 2013 Just go to a shop and they will do a reseal. I had condensation and it is solved now. You don't need to replace the headlights. Quote Link to comment Share on other sites More sharing options...
skidder Posted February 25, 2013 Author Share Posted February 25, 2013 Just go to a shop and they will do a reseal. I had condensation and it is solved now. You don't need to replace the headlights. What sort of shop? I've been to nissan, a body shop and a local mechanic.Nobody wants to touch it as of yet. But thanks anyway I guess. Quote Link to comment Share on other sites More sharing options...
skidder Posted February 25, 2013 Author Share Posted February 25, 2013 (edited) double post.apologies Edited February 25, 2013 by skidder Quote Link to comment Share on other sites More sharing options...
WhackyWill Posted February 25, 2013 Share Posted February 25, 2013 You cannot get that amount of "crap" inside a sealed unit...it has to be external unless the light units have been opened previously...as been said already. I would use MAG Headlight Restorer and give that a try..! Quote Link to comment Share on other sites More sharing options...
WhackyWill Posted February 25, 2013 Share Posted February 25, 2013 Just go to a shop and they will do a reseal. I had condensation and it is solved now. You don't need to replace the headlights. Impossible to do a Re-Seal on Zed headlights...Not sure what you mean about a headlight re-seal.. Quote Link to comment Share on other sites More sharing options...
DoogyRev Posted February 25, 2013 Share Posted February 25, 2013 Yes i've tried polishing the outside. WHat did you polish it with? Megs Metal Polish works a treat Quote Link to comment Share on other sites More sharing options...
skidder Posted February 25, 2013 Author Share Posted February 25, 2013 (edited) Just go to a shop and they will do a reseal. I had condensation and it is solved now. You don't need to replace the headlights. Impossible to do a Re-Seal on Zed headlights...Not sure what you mean about a headlight re-seal.. Its not impossible and many have done it.I've searched long and hard and this has been covered before several times here and on the US forum but they've always been home diy jobs.Usually involves an oven and a re-seal. Cheers Chris Edited February 25, 2013 by skidder Quote Link to comment Share on other sites More sharing options...
catamahu Posted February 26, 2013 Share Posted February 26, 2013 (edited) Believe me, it's far from impossible. An official Nissan shop (dealer) has done it for me and now I have no condensation. I went to them with the problem and they offered to do the re-seal. It took 3-4 hours. I don't know exactly what they done as I left the car there and returned when ready but I suppose they injected some special material arround the joint between the glass and body. Edited February 26, 2013 by catamahu Quote Link to comment Share on other sites More sharing options...
WhackyWill Posted February 26, 2013 Share Posted February 26, 2013 Ok, I live and learn.. Quote Link to comment Share on other sites More sharing options...
Siman350z Posted February 26, 2013 Share Posted February 26, 2013 You can't just use normal polish, you need to try one of the more abrasive polishes mentioned above. Autoglym paint renovator is one I use but bodyshops also reccommend high grade sandpaper (1200+?) which to be honest I haven't had the guts to try out yet. Regular polish won't get near it. Unless you can see droplets, believe me, even though it looks like it's on the inside, it's not! Remember that condensation is distilled water (ie pure) so won't contain any residue which could in theory be left behond to produce a 'smear'. Quote Link to comment Share on other sites More sharing options...
Kev T Posted February 26, 2013 Share Posted February 26, 2013 Toothpaste works a treat on headlights as it is slightly abrasive. Quote Link to comment Share on other sites More sharing options...
catamahu Posted March 1, 2013 Share Posted March 1, 2013 How to re-seal in case of condensation. Quote Link to comment Share on other sites More sharing options...
14N Posted March 1, 2013 Share Posted March 1, 2013 I clay barred mine. Worked a treat. Quote Link to comment Share on other sites More sharing options...
WhackyWill Posted March 1, 2013 Share Posted March 1, 2013 I'm going to clean mine this weekend using Mag Headlight Restorer its an American product and works very well. Quote Link to comment Share on other sites More sharing options...
