Seabee Posted February 21, 2013 Share Posted February 21, 2013 Ok guys as the title says how do I get a cheap key coded to my car? Can you programme them yourself or is it a stealership job? All i can find is the us and uk zeds programme differently, I live in South Wales so any local suggestions would be appreciated also Quote Link to comment Share on other sites More sharing options...
Gonzo88 Posted February 21, 2013 Share Posted February 21, 2013 I was in the same boat and Nissan quoted £200 Quote Link to comment Share on other sites More sharing options...
Seabee Posted February 21, 2013 Author Share Posted February 21, 2013 Did you end up just going with Nissan? Quote Link to comment Share on other sites More sharing options...
Flex Posted February 21, 2013 Share Posted February 21, 2013 These are from the one of the US forums, might not be applicable If not sorry, try google, might churn something up Quote Link to comment Share on other sites More sharing options...
ph 7 Posted February 21, 2013 Share Posted February 21, 2013 Nope, in the UK it is a different process. Involving putting the key in and turning from off to on 6 times....there is a thread on it somewhere. Quote Link to comment Share on other sites More sharing options...
Seabee Posted February 21, 2013 Author Share Posted February 21, 2013 Can't find anything lol Quote Link to comment Share on other sites More sharing options...
ph 7 Posted February 21, 2013 Share Posted February 21, 2013 UK version Quote Link to comment Share on other sites More sharing options...
jables Posted February 21, 2013 Share Posted February 21, 2013 The programming looks easy enough. So is it just a case of getting the key cut and then programming it yourself? How much should you expect to pay for just the key? Quote Link to comment Share on other sites More sharing options...
Seabee Posted February 21, 2013 Author Share Posted February 21, 2013 Yea is this the case? Lol does the transponder need to programmed via obd? Quote Link to comment Share on other sites More sharing options...
Watshot Posted February 21, 2013 Share Posted February 21, 2013 One on ebay for £29 delivered. Couple of cheaper one's if you go abroad. May be worth getting a price from Nissan for a blank sub key and coding it yourself. Quote Link to comment Share on other sites More sharing options...
MidnightRacer Posted February 21, 2013 Share Posted February 21, 2013 the reprogram yourself function is just the keyless entry bit. you need the dealer to program the transponder to your car which is usually the expensive part! Quote Link to comment Share on other sites More sharing options...
Seabee Posted February 21, 2013 Author Share Posted February 21, 2013 I thought it sounded to good to be true lol Quote Link to comment Share on other sites More sharing options...
