Fraktion Posted February 18, 2013 Share Posted February 18, 2013 Hello all. My recent Z purchase came with a bonnet, roof and boot 'wrap' job...which leaves a lot to be desired. I think it's carbon 'effect' as you don't get the little diamonds left when you try to pull it off. It's more a vinyl. Any tips how to safely remove it? I hear a hot gun will do the job. Any risk of paintwork coming off? What's the best way to get rid of the glue underneath once off? I'd like to leave the roof job on but take off the bonnet and boot gubbins. It's only been on for 5 odd weeks. Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted February 18, 2013 Share Posted February 18, 2013 heat gun to soften the vinyl and reactivate the glue, lift and pull gently. something like isoproponol wipes will get rid of the glue Quote Link to comment Share on other sites More sharing options...
catamahu Posted February 18, 2013 Share Posted February 18, 2013 (edited) Heatgun it's a must! Just find an indoor heated place and slowly heat up the part you want to remove step by step. Take someone with you to hold the heatgun and warm up the area while you slowly peel. Carbon wrap is more delicate to remove... Then try to clean what remains with a stain removal solvent made expecially to clean the car paint. You can go ask at a dealer for the solvent they use to remove the protective wax form the new cars. Edited February 18, 2013 by catamahu Quote Link to comment Share on other sites More sharing options...
AliveBoy Posted February 18, 2013 Share Posted February 18, 2013 I normally use Auto Glym intensive tar remover to take glue off my car. Although it might be a pain for large areas! Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted February 18, 2013 Share Posted February 18, 2013 isoproponal panel wipes are what bodyshops use prior toainting to decontaminate and clean a car. Quote Link to comment Share on other sites More sharing options...
cs2000 Posted February 18, 2013 Share Posted February 18, 2013 isoproponal panel wipes are what bodyshops use prior toainting to decontaminate and clean a car. This is correct I removed my old wrap at the weekend with a hot air gun. Obviously they all differ in power but i had mine on about 50% heat, just enough the get the vinyl warm. It still took me about 45 mins to get it all off as the vinyl has to be warm, but once its warn is stretches so you have to be carefull not to tear it! lol Aslong as you arent holding the gun in 1 place you wont hurt the paint, but it wouldnt take a lot of heat to cause damage, just keep it moving. Quote Link to comment Share on other sites More sharing options...
ilogikal1 Posted February 18, 2013 Share Posted February 18, 2013 IPA and/or Tardis will remove the glue residue once you've got the wrap off. Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted February 18, 2013 Share Posted February 18, 2013 just be careful not to pull to hard and without heat as paint can be taken with it Quote Link to comment Share on other sites More sharing options...
