CrumbMC Posted February 15, 2013 Share Posted February 15, 2013 (edited) I picked up the halfords 12V buffer today, never used one before so i tested it out on my freshly cleaned bonnet before it got dark. It seems to oscilate and bounce up and down more than rotate, it took me quite a while to buff, and I still had to wipe it off by hand. Feels like the foam pad which i put the sock things on isn't centrally mounted. I could hear my bonnet vibrating regardless of how much or little pressure i used. - in fact with not much pressure at all it would stop, but like i said its only 12v so that probably shouldn't be a surprise. I'm thinking 2 thinks: maybe the 230V one would be smoother as it should have more torque and hopefully wont feel so cheap. or as this is my first go, are all buffers like this unless i spend a tonne of money. I was going to take it back in the morning as it is really does seem crap or am i just being a cheapskate and want too much for 30 quid? Edited February 15, 2013 by CrumbMC Quote Link to comment Share on other sites More sharing options...
Ekona Posted February 15, 2013 Share Posted February 15, 2013 I binned mine after one crap use. That was a good few years ago now though. Quote Link to comment Share on other sites More sharing options...
peteman35 Posted February 15, 2013 Share Posted February 15, 2013 Take it back or burn it.. the amount of swirls that thing put in my old car was horrifying Quote Link to comment Share on other sites More sharing options...
350 Russ Posted February 15, 2013 Share Posted February 15, 2013 my rotary is smooth and is easy to control. take it back if you still have to receipt Quote Link to comment Share on other sites More sharing options...
downhuman Posted February 15, 2013 Share Posted February 15, 2013 Kill it with fire Seriously mate, not worth using - buy a cheap DA for £70 and that will see you through any situation... or be brave and go proper rotary Quote Link to comment Share on other sites More sharing options...
CrumbMC Posted February 15, 2013 Author Share Posted February 15, 2013 yeah i got the receipt still. only bought it today. going to take it back in the morning just turned it on again. This may sound like an outrageous hyperbole but it actually vibrates my arms more than my 110V sds drill! can't be very good for my car. anyone tried the 240v halfrauds one, is it just as bad? Quote Link to comment Share on other sites More sharing options...
MidnightRacer Posted February 15, 2013 Share Posted February 15, 2013 They are just like you describe and a world away from a flex, two totally different things. I have both and they both have their uses, you should maybe take some time to get used to it. Id say the reason its not buffing off is because you have used too much polish, its a pretty common thing! hope this helps Quote Link to comment Share on other sites More sharing options...
MidnightRacer Posted February 15, 2013 Share Posted February 15, 2013 Also worth mentioning it will be vibrating your hands due to too much pressure, again usually needed because of too much polish. Quote Link to comment Share on other sites More sharing options...
downhuman Posted February 15, 2013 Share Posted February 15, 2013 Even a silverline rotary will be 1,000,000 time better - but a rotary 'proper' can be tricky to use for a novice and can cause damage. Go for a DA or porter cable type random orbital polisher IF you've never used a rotary before... especially with soft jap paint. You'd be a numpty to cause damage with a random orbital Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted February 15, 2013 Share Posted February 15, 2013 This may sound like an outrageous hyperbole but it actually vibrates my arms more than my 110V sds drill! Late Valentines present for the missus maybe? Quote Link to comment Share on other sites More sharing options...
Patch Posted February 15, 2013 Share Posted February 15, 2013 Kestrel rotary is my weapon of choice. Quote Link to comment Share on other sites More sharing options...
WhackyWill Posted February 15, 2013 Share Posted February 15, 2013 Use "elbow grease"....far better results and good exersise, recomend 3M Hand Glaze....!!! Quote Link to comment Share on other sites More sharing options...
downhuman Posted February 15, 2013 Share Posted February 15, 2013 I have a Flex rotary and a Kestral DA - the flex is much better for big panels and quick correction but the DA for fiddly bits and painted plastics Quote Link to comment Share on other sites More sharing options...
Patch Posted February 15, 2013 Share Posted February 15, 2013 Use "elbow grease"....far better results and good exersise, recomend 3M Hand Glaze....!!! Really? Quote Link to comment Share on other sites More sharing options...
CrumbMC Posted February 15, 2013 Author Share Posted February 15, 2013 This may sound like an outrageous hyperbole but it actually vibrates my arms more than my 110V sds drill! Late Valentines present for the missus maybe? Wouldn't want to offer voluntary redundancy Use "elbow grease"....far better results and good exersise, recomend 3M Hand Glaze....!!! Really? Patch frum ukmkivs? 1 Quote Link to comment Share on other sites More sharing options...
Dblock Posted February 15, 2013 Share Posted February 15, 2013 Use "elbow grease"....far better results and good exersise, recomend 3M Hand Glaze....!!! Really? no. Quote Link to comment Share on other sites More sharing options...
Patch Posted February 16, 2013 Share Posted February 16, 2013 (edited) This may sound like an outrageous hyperbole but it actually vibrates my arms more than my 110V sds drill! Late Valentines present for the missus maybe? Wouldn't want to offer voluntary redundancy Use "elbow grease"....far better results and good exersise, recomend 3M Hand Glaze....!!! Really? Patch frum ukmkivs? The one and only. Edited February 16, 2013 by Patch Quote Link to comment Share on other sites More sharing options...
CrumbMC Posted February 16, 2013 Author Share Posted February 16, 2013 Welcome to the club my friend! Quote Link to comment Share on other sites More sharing options...
Patch Posted February 17, 2013 Share Posted February 17, 2013 Welcome to the club my friend! How local are you to Manchester? 1 Quote Link to comment Share on other sites More sharing options...
CrumbMC Posted February 17, 2013 Author Share Posted February 17, 2013 About an hour north... ...kendal Quote Link to comment Share on other sites More sharing options...
Patch Posted February 17, 2013 Share Posted February 17, 2013 Bit of a long drive just to learn how to use a rotary, but it's up to you. Not doing the full car, but more than happy to do a panel or two to give you the idea if you want to buy your own or not. Quote Link to comment Share on other sites More sharing options...
CrumbMC Posted February 17, 2013 Author Share Posted February 17, 2013 Thanks for the offer mate. i did it all by hand yesterday s i wont be doing it for a few months, hopefully the sealant+dodo juice will keep it looking clean for a while. Quote Link to comment Share on other sites More sharing options...
ho02pey Posted February 18, 2013 Share Posted February 18, 2013 I have just bought the meguairs dual action polisher and bought the stage 1 2 3 kit with polishing and finishing pad, im going to clay bar the car then polish it and wax it, i wil post some pics when complete on wednesday keep your eyes peeled in the detailing section of the forum Quote Link to comment Share on other sites More sharing options...
