Throttle Body reset
Vlad
Had my plenum cover off to polish and cleaned TB while at it. Want to do TB reset, just in case i moved valve slightly.
Found this:
http://www.350z-uk.com/topic/53148-ecu-accelerator-pedal-throttle-valve-resets/page__hl__throttle
Question is.... do I need to do everything on that list (incl ECU reset etc) or just "Throttle Valve Closed Position Learning" part? Plenum spacer getting fitted as well.
Thanks
Vlad
:thumbs:
Take like an hour to do it as its a pain in the backside.
Because of the timings required to do it do you mean? I notice a lot of ppl have no luck / joy :shrug:
If you do it with a stop watch, you'll be fine.
Tricky bit is depressing throttle fully five times within 5 seconds, bloody hard to keep count of both in your head.
  • 1 month later...
Im looking to do my TB clean as well but Im now confused.
Dblock I assume you mean "Accelerator Pedal Release Position Learning"
jamesyj suggests doing the "Idle Air Volume Learning (Throttle Position Learning)" as well as "Throttle Valve Closed Position Learning"
Can someone clarify please
