Throttle Controller Issues
Rajzed
Hey guys,
Just purchased a second hand D1 Spec throttle controller from a forum member (I will not disclose the member just in case!) and the accelerator pedal does not click fully in to the the throttle controller connector. Its the male from the throttle controller that doesn't make a click sounds as its pressed into the female.
Also, I believe it is making contact and when turning the ignition (not fully on), it does not provide power to the throttle controller!
What could be the issue??
Regards,
Raj
