The Bounty Bar Kid Posted February 12, 2013 Share Posted February 12, 2013 (edited) So I bought one of these the other day... Just need to wire it in permanently. It comes with a low battery cut out unit, which has three wires. One +12v, one -12v and then one Acc. Where are the easiest places that I should connect these three wires? The unit let's my camera be powered even when the car is turned on, but prevents battery drainage. Oh BTW the camera will be mounted on the front windscreen. Thanx chaps and chapesses! Edited February 12, 2013 by The Bounty Bar Kid Quote Link to comment Share on other sites More sharing options...
The Bounty Bar Kid Posted February 12, 2013 Author Share Posted February 12, 2013 This is the instructions for the smart power unit... Smart Power & Power Magic Pro install We inform the notice for installation of Power Magic & Power Magic Pro. Please refer to the below, once you install it to your vehilcle. <Power Magic & Power Magic Pro installation note> 1. Yellow wire connection If the vehicle has vattery saver, connect the yellow wire BATT(+) to emergency light. (Note 1) 2. Red wire connection please connect after checking that cigar lighter or audio fuse is ACC(+). (Note 2) 3. Multi-booting switch of Power Magic Pro Please install the main body within driver's reach for controlling the switch. 4. Other : Car care during winter season Battery performance is markedly decreased in winter season. Although the Power Magic(Power Magic Pro) normally works, earlier discharge could be occurs according to the vehicle status. Note 1 Battery saver function and Yellow wire Battery Saver is the function for preventing the vehicle's discharge. Vehicles that released recently built-in this function. It turns off automatically all device in vehicle after turning the engine off. Please connect the Yellow wire BATT(+) to emergency light(Do not connect it to taillight and courtesy light) Parking recording can't be executed accoring to the careless installing. Note 2 Audio fuse and Red wire If your vehicle has 2 audio fuses(ACC fuse, BATT fuse) , after checing that cigar lighter or audio fuse is ACC(+) then connect the red wire(ACC(+)) of Power Magic. In case the red wire is connected to wrong places, timer function does not work and multi-booting switch does not work as well. Quote Link to comment Share on other sites More sharing options...
WhackyWill Posted February 12, 2013 Share Posted February 12, 2013 Hi BBK, that look cool...how much, and where did you buy it. ?. Quote Link to comment Share on other sites More sharing options...
The Bounty Bar Kid Posted February 12, 2013 Author Share Posted February 12, 2013 £280 and from http://www.incarcamerasystems.co.uk 1 Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted February 12, 2013 Share Posted February 12, 2013 You'll have to extend wires behind the Headunit, run them behind the dash, run them up the A-Pillar, under the headliner and then have them pop out if the headliner above the rear view mirror or something. Unless you are dash mounting then I suggest making a small hole behind the triple gauges for the wires to come through. Quote Link to comment Share on other sites More sharing options...
The Bounty Bar Kid Posted February 12, 2013 Author Share Posted February 12, 2013 Cheers dude. Now to figure out how to remove the dash/head unit. Search is my friend I know. Quote Link to comment Share on other sites More sharing options...
wizard Posted February 13, 2013 Share Posted February 13, 2013 Easy peasy dip, you just need to find some ignition wires. Head unit wires is a good place to wire something in. Quote Link to comment Share on other sites More sharing options...
Stutopia Posted December 5, 2013 Share Posted December 5, 2013 You ever get this in BBK, I keep looking at them and my wallet is starting to twitch... Quote Link to comment Share on other sites More sharing options...
Richf Posted December 5, 2013 Share Posted December 5, 2013 I have the 400hd , wired it to the back of the cig lighter , dont have it running when the car is parked as thats not an issue for me Had it on my Skyline before, looking at getting another for my daily Quote Link to comment Share on other sites More sharing options...
Stutopia Posted December 5, 2013 Share Posted December 5, 2013 It's the smart power bit that really interests me, with the, er, "characters" round my way. Quote Link to comment Share on other sites More sharing options...
