jamzee500 Posted February 9, 2013 Share Posted February 9, 2013 Hi all, fitted a brand new window motor and followed the reset procedure to the letter, window will roll up and down fine on non auto, and will roll down fine on auto, when i try to auto up it just moves up a couple of mm then back down again, if i role it up non auto an inch then auto it goes up to half way and stops! also it doesnt go up and seal when you shut the door. Any ideas? I hate 350z windows!! Cheers JM Quote Link to comment Share on other sites More sharing options...
Sly@Kaizer Motor Posted February 10, 2013 Share Posted February 10, 2013 It is very difficult to reset these. You have to follow the procedure and pushing the rubber switch isn't easy either, sometimes it takes a few attempt from me too (and I done a few before ). Is the new motor genuine from Nissan ? Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted February 10, 2013 Share Posted February 10, 2013 Check if the rubber cover on the switch in the doorshut is sitting properly. Also make sure that when you do the reset procedure NOT to use the auto function during the reset. Quote Link to comment Share on other sites More sharing options...
M13KYF Posted February 11, 2013 Share Posted February 11, 2013 another method posted ADDITIONAL SERVICE WHEN REMOVING BATTERY NEGATIVE TERMINAL : Special Repair Requirement INFOID:0000000004460995 INITIALIZATION PROCEDURE 1. Disconnect battery negative terminal or power window switch connector. Reconnect it after a minute or more. 2. Door switch is OFF (close). 3. Turn ignition switch ON. 4. Operate power window switch to fully open the window. (This operation is unnecessary if the window is already fully open.) 5. Continue pulling the power window switch AUTO-UP. Even after glass stops at the fully closed position, keep pulling the switch for 3 seconds or more. 6. Initializing procedure is completed. Quote Link to comment Share on other sites More sharing options...
jamzee500 Posted February 11, 2013 Author Share Posted February 11, 2013 Cheers guys, tried the normal reset procedure over and over! will try this new one out, window motor is fronm horsham developments. Cheers Quote Link to comment Share on other sites More sharing options...
