ChickenFB Posted February 8, 2013 Share Posted February 8, 2013 Hello got abit if a issue with my lights yesterday my drives side headlight stop working side an main ok then today I replaced the bulb an still nothin an now the passenger head light is no workin so now iv just got side an main beams An confused anyone had any issues like this thanks Quote Link to comment Share on other sites More sharing options...
Keyser Posted February 9, 2013 Share Posted February 9, 2013 Sounds like an earthing issue to me, can you describe the fault a little better? No Side lights - or do you mean dip and no main beam - you replaced a bulb - still not working? 2 bulbs each side main and dip plus 2 sidelight bulbs, also if you have a tester check they are getting power - do not test inside a HID - you need to test the feeds to the head liights! Quote Link to comment Share on other sites More sharing options...
ChickenFB Posted February 9, 2013 Author Share Posted February 9, 2013 Both side lights work fine. both main beams work fine to start the driver dip beam stopped work then replaced the bulb turned on an now both dont work Quote Link to comment Share on other sites More sharing options...
ChickenFB Posted February 13, 2013 Author Share Posted February 13, 2013 Turned out to be the ballasts failed Quote Link to comment Share on other sites More sharing options...
