Headlamp washers
cs2000
Yes yes yes, another topic on headlamp washers. Just need a bit of advice.
I bought the car a few weeks ago during the bad snow we had, the headlamp washers didnt work then but i assumed they were either frozen up or i was operating then wrong. However, its now dried up and got warner and they still dont work.
I have checked the washers can come out of the bumper freely (pulling them out by hand), this is fine.
I have filled up the washer bottle to the max twice.
I have checked the non return valve (the windscreen washers are working fine).
I have undone the arch liner to check washer fluid is actually getting the the second bottle which it is.
I have operated the washers and made sure theres no random puddles of washer fluid below the car.
But no wash :( I assumed the following was true, but feel free to correct me if im wrong;
To operate the washers, turn on engine and hold the washer button (the one doen near the fuel cap release/ESP off button. This should wash the lights, it should then stop when you let go.
OR......
Car on, healights on and the washers should operate every 3-4 times you wash the window using the steering wheel stalk things.
Nothing seems to work. When i push the washer button (down by the ESP button :thumbdown: ) all i hear is a slight click noise from over by the passenger front light which is where the headlamp washer motor is if im not mistaken, sounds almost like a relay. Im leaning towards the washer pump being duff but wanted someone opinion who has had the car for more than 3 weeks like myself!
