Advice on tyres and spacers
Tomzed
I've got some refurbished wheels for the zed and was looking for advice on tyres sizes and the spacers I may need the wheel sizes are
Front 19x8 half j
Rear 19x10j
And the offsets I'm unsure as I can't really make them out and they don't say et in front is there a way to work these out myself
I believe the fronts are 30
And the rears are either 0 or 10 can't make them out
Here's a post on another forum that explains an easy way to measure your offset:
How To: Measure OFFSET on your Rims
For tyres I would think 245/35 (maybe 235/35) on the front and 275/35 on the rear but if your rear offset really is 0 or 10 then you may be better off with a slightly narrower tyre to prevent rubbing depending on how low you are and how much camber you're running.
I don't think you're going to want spacers on the rear but I would say anything between 10 and 25mm on the front, again depending on camber and ride height.
