Need some help............
choptop
Went to start the zed for the first time after the recent cold snap. Reluctantly started then immediately cut out. Did this a few times and finally started but no acceleration at all. Various warning lights came up on the dash. Turned engine off. Waited a minute and restarted but ignition light has come on and will not go off.
Is there a reset I can do? Advice needed please.
Check the charge on your battery before you go any further.
Z33's do crazy @*!# when battery is dying.
Thanks Lexx. Has never done it before. The light which remains constantly lit is the malfunction indicator. ?? What it is.
How do you do a reset?
Low battery voltage may triggered some fault code in your ECU. There is a way to read and erase it without a computer, but it's not easy. I would recommend to get it checked with a code reader (you can get one for a few ££) or at your local garages. If it can be erased than fine, if not let us know what the code is. I hope this helps.
