scottio87 Posted January 30, 2013 Share Posted January 30, 2013 Hi Guys, I had no idea where to post this or could I find the issue. I have an issue where I get a loud knocking noise when I pull only from cold after its been left overnight or for a long time. As soon as I pull off after the initial noise it stops completeley. Any ideas? Quote Link to comment Share on other sites More sharing options...
theheff Posted January 30, 2013 Share Posted January 30, 2013 Move the headboard away from the wall. 1 Quote Link to comment Share on other sites More sharing options...
theheff Posted January 30, 2013 Share Posted January 30, 2013 Does it seem to be hesitant until the knock. If so it's probably the brakes seized slightly. I get it on mine. I think it's where the brake dust is metal and when it gets damp it rusts giving orange looking discs and causing the brakes to stick to the disc. Quote Link to comment Share on other sites More sharing options...
Husky Posted January 30, 2013 Share Posted January 30, 2013 Anti roll bar drop links perhaps? Quote Link to comment Share on other sites More sharing options...
lamby Posted January 30, 2013 Share Posted January 30, 2013 Sounds like rusted discs due to the recent weather you have been experiencing in the uk Does it seem to be hesitant until the knock. If so it's probably the brakes seized slightly. I get it on mine. I think it's where the brake dust is metal and when it gets damp it rusts giving orange looking discs and causing the brakes to stick to the disc. Quote Link to comment Share on other sites More sharing options...
Sly@Kaizer Motor Posted January 30, 2013 Share Posted January 30, 2013 If it's the disc, than you can avoid it by applying the brake gently before you park it up so the pads are heated up and the water (rain drops) evaporate so the pads and disc not going to stick together. Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted January 30, 2013 Share Posted January 30, 2013 Where's the knock coming from, engine or suspension ? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted January 30, 2013 Share Posted January 30, 2013 More than likely if the noise is from the rear and you only get one crack when moving off from cold then it will more than likely just be the hand brake shoes or pads sticking on. The crack that you get is just them coming unstuck. Try parking up with the handbrake off, but leave in low gear Alex. Quote Link to comment Share on other sites More sharing options...
scubapics Posted January 30, 2013 Share Posted January 30, 2013 Move the headboard away from the wall. Or you will go bald. Quote Link to comment Share on other sites More sharing options...
scottio87 Posted January 30, 2013 Author Share Posted January 30, 2013 Cheers guys for the response. Yeah it hesitant, not an instant clunk. The disks are showing a some rust on the rears now, so probably is that. I'll try to leave it in gear over night tomorrow and see if that changes anything. Thanks again. Quote Link to comment Share on other sites More sharing options...
