KyleR Posted January 27, 2013 Share Posted January 27, 2013 Hey, I've read loads about people's suspension knocking when on uneven surfaces, going over ramps etc etc, but my problem is a little different but may or may not be the same cause. When stationary/traveling very very slowly, I get a single clunk/ knock from the front end, I believe the drivers side. Reading about others problems, everyone tells them banana bar or drop links, however this is for a slightly different problem that I can't seem to find mentioned on the forum. To me instinct tells me something loose, but has anyone any idea what it could be? Thanks Kyle Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted January 27, 2013 Share Posted January 27, 2013 Let's be clear on this: You get a knock when you are stationary ? Alex Quote Link to comment Share on other sites More sharing options...
KyleR Posted January 27, 2013 Author Share Posted January 27, 2013 Yes Alex, stationary but turning the steering wheel to the right, I probably should have mentioned that in the original post :face palm: Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted January 27, 2013 Share Posted January 27, 2013 Engine running or switched off? Quote Link to comment Share on other sites More sharing options...
KyleR Posted January 27, 2013 Author Share Posted January 27, 2013 Sorry or taking a while to reply, was swapping the boot struts out since it stopped raining or 5 minutes. Engine running Alex, never attempted to turn the steering without power. Should I see if I can get it to happen with ignition off? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted January 27, 2013 Share Posted January 27, 2013 Should be very easy to trace the knock so just get the car on to a 4 poster flat bed ramp and get someone to move the steering to induce the fault whilst some one is checking steering/suspension components underneath. This procedure will remove all guesswork. Alex. Quote Link to comment Share on other sites More sharing options...
KyleR Posted January 27, 2013 Author Share Posted January 27, 2013 Unfortunately nothing I can do myself then. Thanks Alex Quote Link to comment Share on other sites More sharing options...
