dave_c Posted January 23, 2013 Share Posted January 23, 2013 Hi! Today my 350z boot release has stopped working. When I unlock it with the key fob the boot makes no noise and when I press the boot release button it does nothing. I've pulled the emergency release under the strut bar and that all works, just seems the electric release button is broken.... Is there a fuse for this or anything? Anyone else got any ideas? Quote Link to comment Share on other sites More sharing options...
Sly@Kaizer Motor Posted January 25, 2013 Share Posted January 25, 2013 Back door lock getting the power from the BCM (Body Control Module) there isn't a dedicated fuse for that, so if only that door doesn't work I suspect a wiring fault or the lock failed. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted January 25, 2013 Share Posted January 25, 2013 Dave, The issue will probably be the boot lock actuator which is connected to the boot lock. Just remove the rear trim and check that the actuator is getting power. Preowned boot locks and actuators are in stock if required. Alex. 1 Quote Link to comment Share on other sites More sharing options...
dave_c Posted January 26, 2013 Author Share Posted January 26, 2013 Thanks Alex, I'll have a look today. Quote Link to comment Share on other sites More sharing options...
MartynB85 Posted May 6, 2013 Share Posted May 6, 2013 Sorry to bump an old thread, but did you find out what the issue was? Quote Link to comment Share on other sites More sharing options...
N4eay Posted September 21, 2016 Share Posted September 21, 2016 (edited) Again sorry to revive an old thread but as MartynB85 said, did you have a resolution to this, I’m having the same issue, I have to wiggle the button for a while to get the boot to open. Thanks Edited September 21, 2016 by N4eay Quote Link to comment Share on other sites More sharing options...
Fletch350 Posted September 2, 2020 Share Posted September 2, 2020 On 25/01/2013 at 21:36, ZMANALEX said: Dave, The issue will probably be the boot lock actuator which is connected to the boot lock. Just remove the rear trim and check that the actuator is getting power. Preowned boot locks and actuators are in stock if required. Alex. To revive an old thread...are used actuators still available? Cheers. Quote Link to comment Share on other sites More sharing options...
