350Z Japspeed s/s decats, nearly new, 230miles, and one LED rear light - SOLD
msisleman
I'm selling my decats after only having them fitted for a couple of days - bit loud for me. They have done 230 miles, so are obviously in like new condition, with some minor coking from light use.
£60 posted. Or £80 posted with zmanalex's O2 simulator's, which stops the MIL lighting on the dash due to a cat threshold DTC code.
I also have one rear 2006 on LED tail light. This works fine, however has a crack in it, as can be seen in the photos. This may be fixable by someone, maybe using the plastic outer skin from an old tail light and fitting in place of the cracked one on this? £30 posted.
Pickup is also possible from Braintree or Basildon, Essex.
Cheers,
Craig.
Edited by msisleman
You can do either and it will work. However due to the post cat lambda sensors picking up the fact that the cats aren't working (as they're not there), a DTC code will come up which will switch the MIL on on the dash if you don't use these items, or get the code switched off during a remap session.
