CharlieSmith Posted January 18, 2013 Share Posted January 18, 2013 This morning I went to open my Z and to my surprise the key fob was not working. It had been snowing so I thought maybe the signal couldn't get through. Anyway after getting into the car manually (key-in-door) I discovered the entire electrical system is off. It has not been driven in 2 days but the battary was showing completely normal readings on last shut down and I'm skeptical if it is a flat battary as absolutly no indication of any power to any car system is showing. My first inkling is it is a fuse problem. I've looked at the two faily accessable fuse boxes (by drivers foot and under hood next to battary) and there appears to be no problems on first glances but I hear fuse #82 is the master fuse and without knowing where that is located I have no way to check it. Another slight issue was when I opened the under hood fuse box I heard a sound as if something had just fallen into the battary compartment that may have come loose in the fuse box. If anyone (with a complete set of under hood fuses) could confirm in the picture attached if my set of under hood fuses are indeed complete or not, that would be super to rule out a missing and now lost fuse. Obivously the car can't operate a single electrical feature let alone go anywhere so before calling for roadside assistence I would like to get a better idea of the problem. The only abnormality in the last few days is that the weather has been very cold. Quote Link to comment Share on other sites More sharing options...
Ebized Posted January 18, 2013 Share Posted January 18, 2013 More likely your battery, I would have thought - if you are a member of a breakdown outfit just call them out, but no doubt they are busy today . Quote Link to comment Share on other sites More sharing options...
Humpy Posted January 18, 2013 Share Posted January 18, 2013 Sounds totally like the battery to me and this cold weather has probably finished it off. My battery decided to die on me about two months with no warning or anything, changed battery and bingo! Quote Link to comment Share on other sites More sharing options...
rothers2901 Posted January 19, 2013 Share Posted January 19, 2013 Sounds totally like the battery to me and this cold weather has probably finished it off. My battery decided to die on me about two months with no warning or anything, changed battery and bingo! +1 Quote Link to comment Share on other sites More sharing options...
buster Posted January 19, 2013 Share Posted January 19, 2013 +2 Quote Link to comment Share on other sites More sharing options...
Sam Mcgoo Posted January 19, 2013 Share Posted January 19, 2013 Definitely check the battery first. Have got a multimeter or anything you can check your battery voltage with? Quote Link to comment Share on other sites More sharing options...
Ricey Posted January 19, 2013 Share Posted January 19, 2013 Battery tends to totally crap out on the zed rather than slow degradation Quote Link to comment Share on other sites More sharing options...
CharlieSmith Posted January 19, 2013 Author Share Posted January 19, 2013 Anyone try recharging from the mains before getting a new battery? FYI if you ever need to change a fuse on the panel in the "passenger compartment" hire a chinese contortionist. Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted January 19, 2013 Share Posted January 19, 2013 I wouldn't bother trying to recharge unless you know it is a very new battery, if it is on it's last legs you will get all sorts of problems..... best to bite the bullet and get a new one Quote Link to comment Share on other sites More sharing options...
CharlieSmith Posted January 20, 2013 Author Share Posted January 20, 2013 New battery in, problem solved! Thanks. Quote Link to comment Share on other sites More sharing options...
Ebized Posted January 20, 2013 Share Posted January 20, 2013 New battery in, problem solved! Thanks. Good news Quote Link to comment Share on other sites More sharing options...
