james87 Posted January 16, 2013 Share Posted January 16, 2013 Hi all, Just bought myself a 57 plate facelift 313. I have an issue when pulling away slowly in first and second gear, once off the clutch i notice that the car jolts quite badly when increasing the speed?!? This only seems to happen under 2k revs when the car is fully warmed up. The car is going into the garage next week but was wondering if anyone has any ideas what might be causing this so i can help my mechanic resolve the problem? Thanks Quote Link to comment Share on other sites More sharing options...
The Bounty Bar Kid Posted January 16, 2013 Share Posted January 16, 2013 Quote Link to comment Share on other sites More sharing options...
lmc Posted January 16, 2013 Share Posted January 16, 2013 Quote Link to comment Share on other sites More sharing options...
james87 Posted January 17, 2013 Author Share Posted January 17, 2013 thank you!! About time i got on here as this is my 2nd 350z Quote Link to comment Share on other sites More sharing options...
DoogyRev Posted January 17, 2013 Share Posted January 17, 2013 Welcome Along how may miles has it done? Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted January 17, 2013 Share Posted January 17, 2013 might need a Tb clean and a reset Quote Link to comment Share on other sites More sharing options...
james87 Posted January 22, 2013 Author Share Posted January 22, 2013 ok thanks. it has done 57k miles Quote Link to comment Share on other sites More sharing options...
FUG Posted January 22, 2013 Share Posted January 22, 2013 Quote Link to comment Share on other sites More sharing options...
AMT Posted January 22, 2013 Share Posted January 22, 2013 (edited) Jolts in first and second in low revs... (and its winter)... perhaps your givin' it too much welly off the line or too little grip when your pulling away? (the ESP comes down like an anvil and your car will jolt doin this, although you'll see the light flicker too.... just a guess lol Can happen if the tyres are cold and you go to accelerate hardish in the lower gears, i came out of work jumped on the M8 and it still lit up in 3rd, although I was pushing a bit for a couple of secs coming off the sliproad... Oh and welcome!... I really do hope thats what it is and not a more serious issue! Edited January 22, 2013 by AMT Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted January 22, 2013 Share Posted January 22, 2013 sounds like it might be a vac leak, or dirty throttle body, get the ecu read and see if there are any hidden codes 1 Quote Link to comment Share on other sites More sharing options...
james87 Posted January 22, 2013 Author Share Posted January 22, 2013 100% sure its not traction control coming in as this is my second 350 and the light never shows, it happens only when you drive gently? if you boot it away its fine!! some good advice tho so thank you all!!! thanks for all the messages Quote Link to comment Share on other sites More sharing options...
AMT Posted January 23, 2013 Share Posted January 23, 2013 Ah sorry! Didn't realise it was your 2nd...or I haven't read it properly... Quote Link to comment Share on other sites More sharing options...
james87 Posted January 29, 2013 Author Share Posted January 29, 2013 Its in there some where but no worries pal! Going in this week so any other ideas would be great!! cheers people!!! Quote Link to comment Share on other sites More sharing options...
jumping350 Posted January 29, 2013 Share Posted January 29, 2013 Mass air flow sensor maybe needs clean or replacing Quote Link to comment Share on other sites More sharing options...
rabbitstew Posted January 29, 2013 Share Posted January 29, 2013 Hmmm... doesnt sound good, i never had anything like that with my 313. Be interesting to find out what it is. Quote Link to comment Share on other sites More sharing options...
WhackyWill Posted January 29, 2013 Share Posted January 29, 2013 I assume you are running it on 98 RON fuel and not 95, Sounds like the Throttle Body and MAF need a good clean and re-set . Have it checked for error codes, or as "rtbiscuit" said it could be a vac leak. May also look at a breakdown of a coil pack. Good Luck let us know what it is.. :thumbs: Quote Link to comment Share on other sites More sharing options...
M13KYF Posted January 29, 2013 Share Posted January 29, 2013 spark plugs, when were they last changed? Quote Link to comment Share on other sites More sharing options...
Chris AME Posted January 29, 2013 Share Posted January 29, 2013 As said above try throttle body clean and reset as a first option, then Maf and check when spark plugs where last changed Quote Link to comment Share on other sites More sharing options...
Roscoe Posted August 6, 2013 Share Posted August 6, 2013 Did this ever get resolved? I'm having the same with mine! No fault codes!! Quote Link to comment Share on other sites More sharing options...
Jp606 Posted August 11, 2013 Share Posted August 11, 2013 Could be spark plugs, misfire perhaps? Had a similar thing on another car once. Quote Link to comment Share on other sites More sharing options...
Roscoe Posted August 12, 2013 Share Posted August 12, 2013 Plugs were supposedly changed on last service 60k 3000 miles ago.. Could chuck another set in Quote Link to comment Share on other sites More sharing options...
Jp606 Posted August 12, 2013 Share Posted August 12, 2013 Has it done it since the service? Could be a incorrectly gapped plug/damaged plug? Quote Link to comment Share on other sites More sharing options...
Roscoe Posted August 13, 2013 Share Posted August 13, 2013 Not sure as previous owner had it serviced and then sold it within a few months. Il get the plugs out see what they are like Quote Link to comment Share on other sites More sharing options...
Roscoe Posted August 13, 2013 Share Posted August 13, 2013 Just been out for an hour and the hesitation/bog is defiantly softer when the engine is hot. Only starts doing it after about 10 minutes of driving once its warmed up. Always happens under 2000 rpm on light throttle Quote Link to comment Share on other sites More sharing options...
fergie1471 Posted August 20, 2013 Share Posted August 20, 2013 My 313 is doing exactly the same thing. Did you ever get it sorted? Quote Link to comment Share on other sites More sharing options...
