Jimbo Posted April 10, 2007 Share Posted April 10, 2007 I want to use the Alpine DVD player which I have but my car has the Bose system in it. Can you buy a harness to use the new headunit??? I have found loads for the non bose car but nothing for mine, any help please Quote Link to comment Share on other sites More sharing options...
Ian Posted April 10, 2007 Share Posted April 10, 2007 http://www.350z-uk.com/forum/viewtopic.php?t=6979 Shopping list I had was Pac Roem kit Micra Speaker Harness you need the PC2-76-4 Single din dash surround can be found on ebay Also dont forget to buy an aerial adaptor Hope this helps Quote Link to comment Share on other sites More sharing options...
Chris`I Posted April 10, 2007 Share Posted April 10, 2007 Ian, Quick question (dont worry it applies to Jimbo too). I am trying to work out the wiring with the PAC-ROEM kit. From the pic in eBay link above, does it link like this: [NEW_HU]---(RAD-UNV)---[PAC-OEM]---(AMP-NIS2)---[bOSE_AMP] In which case you would place the micra kit between the RAD-UNV (I assume stands for Radio Universal i.e. not specific) and the HU? Do you have to splice the wires into the Micra harness or is it a case of plug and play? If you have to splce, could you not just splice it straight onto the HU harness? Or is the idea you splice it to the micra harness and save the original HU harness? Hope that makes sense, just want to make sure I have the wiring right Quote Link to comment Share on other sites More sharing options...
Ian Posted April 10, 2007 Share Posted April 10, 2007 I cant remember 100% but i think this is how i did it. [NEW_HU]---(RAD-UNV)---[PAC-OEM]---(AMP-NIS2)---[bOSE_AMP] The speaker harness runs from the speakers to the headunit - the HU harness was spliced into the Micra harness. The PAC-OEM plugs direct into the amp and then also splices into the HU harness. I **think** that is correct ill try and get hold of my uncle who did the majority of the work later & see if he remembers but im pretty sure thats the way it was done Quote Link to comment Share on other sites More sharing options...
Rob_Quads Posted April 10, 2007 Share Posted April 10, 2007 Pretty sure you can use the standard Autoleads Micra loom and then you just need to add in 1 cable to the factory look (connect the remote trigger) to get the amp to turn on. Quote Link to comment Share on other sites More sharing options...
Chris`I Posted April 10, 2007 Share Posted April 10, 2007 Doesnt that cause it to come out really quiet? I thought this ROEM box was meant to boost the signal? Quote Link to comment Share on other sites More sharing options...
Ian Posted April 10, 2007 Share Posted April 10, 2007 It would make it a lot easier for future installs if it didnt need the ROEM box. From what ive read around here & some of the US forums it seemed that the ROEM box was essential to getting the amp working with the new HU. I think ive read that the amp can be bypassed, maybe that can be done by missing out the ROEM box? Quote Link to comment Share on other sites More sharing options...
Jimbo Posted April 11, 2007 Author Share Posted April 11, 2007 Im as confused as a confused person I have ordered the micra loom, will that plug straight in to the Bose loom? If so which cable on the bose loom is the amp trigger so I can plug my blue remote lead from the alpine in Quote Link to comment Share on other sites More sharing options...
Jimbo Posted April 11, 2007 Author Share Posted April 11, 2007 Pretty sure you can use the standard Autoleads Micra loom and then you just need to add in 1 cable to the factory look (connect the remote trigger) to get the amp to turn on. ANy ideas which cable, as ive bought the Micra Cable Quote Link to comment Share on other sites More sharing options...
