Replay XD Lightweight Video Cameras
Tarmac@TarmacSportz
Hailed as the best lightweight camera on the market and perfect for HD recording from your car I thought it only fair to offer you guys the best deal in the country !!
The Replay XD was designed by a group of racing professionals with over 50 years of experience in the high performance racing industry. The development team saw the need for ultra-lightweight cameras that could capture never before seen video footage from the most extreme racing and action environments on earth. The Replay XD has been put through the most grueling conditions possible and has come out unscathed with crystal clear footage. The Replay XD goal is to offer the most technologically advanced HD video camera systems available today.
Replay XD1080 HD video camera is all about small and simple. Starting with the small design of the original Replay XD video camera and a clean sheet of paper, they managed to put full HD video into a small package. Featuring a water-resistant, hard anodized, rugged aluminum housing for your extreme adventures. The XD1080 is the smallest and lightest full HD video action-camera on the market. Simple, ON/OFF and Start/Stop make the Replay XD1080 camera easy to operate. Simply turn it ON and Press Record to Start. The built-in LED & Vibration Feedback tells you that you're ready to go.
Heres a vid of one of the Time Attack drivers and motocross riders in the states
http://replayxd.com/...-xd/chris-rado/
http://replayxd.com/...justin-brayton/
These retail in the UK for £300+ but Tarmac price for a limited time is £255
Resolution and at what fps?
Maximum memory card size acceptable?
Connectivity?
Battery life?
Replay XD 1080 Technical Specifications
Removable Storage microSDHC (up to 32GB)
4GB micro SDHC Included Ports HDMI 1.3a Output
-Live HD Video Streaming
-HD Video & Photo Playback, Thumbnail Display, Play/Stop, Skip Forward/Reverse, Menu On/Off
-External Mic/Audio Line-In
USB 2.0 Mini 8-pin
-Charge and Sync
-Timecode Out (with HW Data Kit)
microSDHC slot
-up to 32 GB Power AC Power 100~240 V, 50~60 Hz
Rechargeable Internal Li-ion Battery 3.7 V, 750 mAh*
up to 122 Minute Record Time* Housing Durable Aluminum Housing
-Type-1 Black Anodized
-Round for 360º Mounting Rotation
-Impact Resistant
Black with Laser Etched Logos
-Easy Alignment
-Discrete Placement
O-ring Sealed
-Front and Rear Bezel
-Exterior Buttons
Weather Resistant Size 28 mm Dia. x 93 mm Length, 27 mm Mounting Dia.
1.1 in Dia. x 3.6 in Length, 1.063 in Mounting Dia.
96.2 mm with Lanyard Cap
3.78 in with Lanyard Cap Weight 85 grams (including battery & microSDHC)
3 ounces Control On Top: Power “On/Off†& Select “Record, Stop, Playback, Clip File†Buttons with Vibration Feedback
On the Back: Mode “1080P, 960P, 720P, Photo, Heads-up On/Off, FPS “60 fps, 30 fps, 3, 5, 15, 30 Sec.
Audio: Internal Mic & External Mic Selection Photo Mode 5 MP JPEG Photo 2592 x 1944
1 Photo per 3, 5, 15, 30 sec Video Settings H.264 Codec, Quicktime .mov file type
Live HD Playback, Live HD View, Live HD Streaming
Bitrate Adjustment: High, Medium, Low
Exposure Control EV Adjustment
Auto Exposure Metering: Center, Average, Spot
Automatic White Balance with Adjustment
Contrast Adjustment
Sharpness Adjustment
Saturation Adjustment
Microphone Audio Gain Control
Date and Time Adjustment
Heads-up Display via HDMI Port On/Off Video Resolution 5 MP (2592 x 1944) CMOS Sensor
1080P 1920 x 1080, 30 fps, Bitrate M(bit/s) = up to 15M
960P 1280 x 960, 30 fps, Bitrate M(bit/s) = up to 15M
720P 1280 x 720, 60 fps, Bitrate M(bit/s) = up to 15M
720P 1280 x 720, 30 fps, Bitrate M(bit/s) = up to 15M
HDMI HD Video Streaming, Real-time HD 1080.
NTSC 30/60 and PAL 25/50 option Optics F3.1±5% Wide Angle
110.5 Degrees @ 1080P
135 Degrees @ 960P, 720P
135 Degrees @ Photo
1.3V/lux-sec Light Sensitivity Lens Cover Replaceable Aluminum Bezel and Lens Cover Audio Internal Omnidirectional Microphone
AAC and AC3 2-channel
48K, 16-bit, Auto Gain
External Mic-in 0.707 Vrms Power Supply 5V +/- 0.5V / 2A Windows Intel® Core Duo® or higher
Windows® XP with Service Pack 3, Windows Vista, Windows 7
1920 x 1080 screen resolution
USB 2.0 Port, Mouse Macintosh Intel® Core Duo® or higher
Mac OS X v.10.5, 10.6, 10.7
USB 2.0 Port, Mouse Replay XD 1080 Kit Replay XD1080 Camera, HeimLock adjustable mount, LowBoy fixed mount,2 Flat Base VHB SnapTrays, 2 Curved Base VHB SnapTrays, 4GB microSDHC Card,USB Cable, HDMI Cable, Univ. USB DC Wall Adapter, Car USB Charger, Nylon Ballistic Case, Silk Camera Bag, Windbreaker Decal Kit, Replay XD Decals, User Guide
Swinging it back round on topic...
This camera looks pretty good actually, and a decent price to boot.
For my particular needs its the rolling shutter comparisons that I'm interested in when it comes to camera vs camera. But that's hugely specific to me and what I'd be doing to the footage.
  • 1 month later...
