Zed Leppelin | Custom Oil Catch Can Complete - June 5th
ironhide
Cars looking great. Is there a guide somewhere telling us where to put the ground kit so we don't **** up the electrics? :lol:
I just looked online at pics of the Stillen kit and the Horsham kit (Which has a guide) and made sure I contacted the common points. So long as you don't put a positive to a negative you can't go wrong.
Bit of an update from the past week. Wanted to install an oil catch can, but didn't want some generic eBay thing and ideally something baffled without spending £200 for a Mishimoto one!!
Managed to pick this up off the eBay which was ideal as it has a sight, good positioning for the inlet/outlet and a cap to check the contents.
Quick clean up:
Then got some M10 to An8 adaptors in black (rather than the standard blue/red)
But the ID on the M10 end was very narrow
So drilled it bigger :)
And fitted
Next up, purple fittings (But of course)
And some black braided hose, wanted to be different here.
Now to make the catch can baffled, cut out a length of aluminium.
Trimmed and test fitted
Next the baffled bit, drilled lots of holes and cut two lines so it could be bent to create a filter effect.
Bent the baffle into place so air can pass down one side and then up the other through the baffle. also drilled holes in the divider to allow air through should the oil level creep up higher than the main baffle.
Test fit and added a support piece to stop it floating around inside the catch can.
Next up some stainless mesh to act as secondary baffling. Opted for this rather than steel wool which can disintegrate.
Folded it up a bit
And inserted
Next up I needed to create a bracket to allow the catch can to fit securely against the firewall
Test fit in situ
Plummed up and cut lengths of black braided hose, also added a cheeky purple finisher to the vaccum hose from the top of the manifold to the ABS system.
Strut brace back in position
Then added some extra stickers to celebrate completion of 'project oil catch can' :yahoo:
Next up is to change the radiator overflow hose to black and add a purple finisher :)
Also to replace the oil level sight pipe on the catch can, so got some clear pipe.
Cut to length...
and fitted...much better.
So far after a week of blasting about I know it's working as there is a tiny amount of oil at the bottom of the can and the outlet/top of the baffle is squeaky clean :teeth:
That's all for now...just need something to tidy up the engine bay a little bit more... B)
Edited by ironhide
