rear parking sensors not working
Evening,
I have a black GT4 and 3 weeks ago my factory fitted rear parking sensors completely stopped working.
The beep when I put it into reverse has also stopped.
Am I right in stating that only 350z's with sensors only beep when put into reverse?(i've owned two 350z and they both beeped when put into reverse although they both had rear sensors)
Should I take it to a garage as reversing is a right nightmare in this car and i've sort of got used to the rear sensors activating or could it be something simple?
There is no switch to turn them on or off.
Any advice appreciated.
Cheers,
Chris
Posted (edited)
Parking sensors were never a factory option they were a dealer fit and they used different systems. There all pretty much the same though. It could just be the control unit has lost power, its usually under the boot carpet and foam on the passenger side of the car.
They take there power from the reverse light so it could be hear where your problem is. To gain access you'll need to remove the light cluster.
Mine went so I replaced it with a kit of ebay that cost £18.
Edited by un1eash
