Clutch Squeak
Dave_the_Rave
Hello All
Im new to the forum and 350z ownership!!
loving the car at the moment a 04 GM with 40k on the clock :D but i have recently noticed there is a squeaking noise when the clutch pedal is fully depressed! does not happen all the time and has not affected the clutch action or movement in anyway! its just very annoying!!!
I have found it could be the linkage that connects to the Clutch release bearing? and it requires greasing? anybody else be able to shine some light on the situation?
Thanks
David
I have the same problem occasionally.
I think you'll have to recline the drivers seat as much as possible, and get you bum on the seat with your head under the pedals, apply some grease to the hinge points.
I'm just guessing here.
As always, use the search as well as it comes up often.
