Rajzed Posted January 7, 2013 Share Posted January 7, 2013 Hi guys, This is really bothering me! My CEL light keeps coming on. I have done the diagnostics and the codes are as follows: P0159 P0139 P1146/47 P1166/67 I know that the last 4 codes are the heated O2 Sensors 2 (P1146/47,P1166/67) but not entirely sure what the first 2 codes are. I have attached a picture of my Cats and believe the Kinetix High Flow Cat has a spacer already installed? Can anyone confirm whether they have? I don't know what to do! I was about to purchase some O2 sensor spacers but it looks like I already have them haha. I have removed the code a couple of times and it has got rid of the CEL light for like a month each time I removed the light. Any help would be very much appreciated!!! Kind Regards, Raj Quote Link to comment Share on other sites More sharing options...
DoogyRev Posted January 7, 2013 Share Posted January 7, 2013 No pic Quote Link to comment Share on other sites More sharing options...
Rajzed Posted January 7, 2013 Author Share Posted January 7, 2013 Aaah! I can't upload the photo on here. But here is a link: http://s1322.beta.ph...amtora/library/ Apologies for using photobucket, but I have apparently used my maximum allowance for photo uploading! Added the pic for you, Ebized Quote Link to comment Share on other sites More sharing options...
Keyser Posted January 7, 2013 Share Posted January 7, 2013 P0139 O2 Sensor Circuit Slow Response (Bank 1 Sensor 2) P0159 O2 Sensor Circuit Slow Response (Bank 2 Sensor 2) P0146 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 3) P0147 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 3) P0166 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 3) P0167 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3) Sounds like the spacers are stopping a reading Does it happen after a long hard run? Quote Link to comment Share on other sites More sharing options...
Rajzed Posted January 7, 2013 Author Share Posted January 7, 2013 Hey Keyser, the codes I'm getting are P1146,1147 and P1166,1167 and not P0146,0147 and P0166,0167 dude. I think the last 4 are heated O2 sensors right? I shouldn't be getting these with spacers in :( Quote Link to comment Share on other sites More sharing options...
Keyser Posted January 7, 2013 Share Posted January 7, 2013 I shoulda gone to spec savers Try again - P1146 Heated O2 Sensor 2 P1147 Heated O2 Sensor 2 P1166 Heated O2 Sensor 2 P1167 Heated O2 Sensor 2 No but they are all the same sensor so it may be a faulty sensor? - having said that Buster gets them on his Zed every few weeks since fitting the HFC's with spacers - I get them as well but had them disabled in the UPREV but I get loads of warnings my favourite is P0103 Mass or Volume Air Flow Circuit High Input Doesn't seem to like the NOS Quote Link to comment Share on other sites More sharing options...
Sam Mcgoo Posted January 7, 2013 Share Posted January 7, 2013 Hey Keyser, the codes I'm getting are P1146,1147 and P1166,1167 and not P0146,0147 and P0166,0167 dude. I think the last 4 are heated O2 sensors right? I shouldn't be getting these with spacers in :( I used to have kinetic hfc and got the same codes as you regularly. I fitted the spacers and it it reduced it significantly, once every month or so after a hard run or if particularly cold outside. I wouldn't worry about it. Just keep checking the codes and if its the same ones reset them, wont do ant harm. Alternatively, getting an UPREV tune will turn them off perminantly and make the most of your mods. Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted January 7, 2013 Share Posted January 7, 2013 Always worse in the winter too, I used to get loads of faults till I got them turned off via upRev too Quote Link to comment Share on other sites More sharing options...
Rajzed Posted January 9, 2013 Author Share Posted January 9, 2013 Looks like I need this Uprev tune. Might as well get a plenum spacer and get the full works done! Ohh the excitement..! Quote Link to comment Share on other sites More sharing options...
Adam rs Posted April 3, 2013 Share Posted April 3, 2013 I have exactly the same codes as you,Had my uprev done 12 months ago never had a problem till sunday. I have HFC's but they were fitted before the uprev. Funny the cold weather is mentioned as ive never used the car when its been this cold. I will keep re-setting the light and will be interested to see if it is the weather. I will add to the post if anything changes. Quote Link to comment Share on other sites More sharing options...
Parsnip Posted April 4, 2013 Share Posted April 4, 2013 Berks + Nismo (+piggyback ECU) - get these codes all the time when its cold - either pedal dance or OBD2 reset when I can be bothered. Rarely seen over the summer months (few and far between in Aberdeen) Quote Link to comment Share on other sites More sharing options...
