Coilovers vs Lowering springs - real word ride height
D8NMT
  • 4 weeks later...
30mm drop bc coilvers
Drive the car pretty muxh any where on roads in south africa.
Its a bit tricky in places but nothing a few angles wont sort out
Sent from my GT-I9300 using Tapatalk 2
Thats a nice car. Do the lions come up and use it as a mirror to combe there hair?
Edited by 4RE Leather
Thats a nice car. Do the lions come uo and use it as a mirror to combe there hair?
Txs lol I tend to stay in the car haha.
personally i d say go for the coilovers.....that way your get the added bonus of adjustsable dampering as well as height control.run mine on the tien super street set up....has cost me a new y pipe but a small price in my eyes :D
oh and repairs to the v2 front bumper.
What sort of skirts do you have Buster?
Camber arms required for 30mm? Or any lower than that you mean?
Well over 25ish you will need front and rear camber arms. I'm lowered on 30mm with camber arms etc but no rubbing.
You do not need front camber arms for that drop.
I have dropped mine about 40mm on the front and my camber is at -2degrees which is fine.
The rears definitely need new camber arms as well as a larger toe adjustment. The Eibach kit is the only kit I know of that supplys this.
You might damage the standard dampers but I've had my a3 lowered for three years now 30mm drop all round with no problems surely its better to use the standard dampers until they fail then up rate the dampers, you might as well get your use out of them. Lowering springs are ok as there cheap but coil overs completely change the car I have so much more confidence in mine since fitting the coil overs well worth the money if you drive the car properly if you just pose then buy springs. I've lowered mine about 50 mm I think and I don't need all these different camber arms mine runs fine however clearance is a problem now.
  • 2 years later...
