jumping350 Posted December 30, 2012 Share Posted December 30, 2012 had oem jdm steering wheel in with buttons just on the left side of wheel..swapped it out for a one off from 4RE (with no buttons blank plates either side) but horn doesnt work now...buttons were plugged in and yellow wire was plugged into wheel (earth?) but now i have no buttons what do i do? cant plug old buttons in as there is no where to put them any advice would be great Quote Link to comment Share on other sites More sharing options...
Keyser Posted December 30, 2012 Share Posted December 30, 2012 (edited) Don't see it being the button's on the side, I haven't looked at a 350z setup but usually the horn wire in the steering wheel simply creates an earth for the horns. Sometimes there is a plate and a contact ring above it pressing the horn lets the 2 plates touch. Have you got a volt meter? I assume the horn worked on the old wheel so you should be able to see if a second wire needs connecting. Sorry can't be much help as I haven't taken one apart. Edited December 30, 2012 by Keyser Quote Link to comment Share on other sites More sharing options...
4RE Leather Posted December 30, 2012 Share Posted December 30, 2012 (edited) Viagra? It really is a strange one so what I suggest is you still have the old wheel (Swine) which I believe worked. The contact to engage the horn is when you press down the hole of the silver bracket underneath the airbag touches the bottom plate and is resisted by the 2 coil springs like the one that pinged across your hall carpet the other day. It may be that the 3 left hand side configuration you originally had is somehow logged into the memory of the ECU. There is only one solution in your case and that is we reverse everything we did in a bid to find out what is going on. We will start off by sticking your old wheel back and if it works take it from there. Its a matter of getting to mine in decent weather as all the tork keys and stuff are here. Ring me to sort out a time etc. Edited December 30, 2012 by 4RE Leather Quote Link to comment Share on other sites More sharing options...
jumping350 Posted December 30, 2012 Author Share Posted December 30, 2012 (edited) thanks chris il take a look at that maybe i can earth it somehow and see if that works...... pete !! yeah was hoping i wouldnt have to reverse but looks like i will now, that wheel is yours just wanted to try all options before i let it go and stuck with no horn at all! Il shall take look at next few days weather and ring you Thanks guys why do i always find the problems no one ever comes across Edited December 30, 2012 by jumping350 1 Quote Link to comment Share on other sites More sharing options...
Ian Posted December 30, 2012 Share Posted December 30, 2012 Blown fuse? If not do as Chris says & check the ground Quote Link to comment Share on other sites More sharing options...
glrnet Posted December 30, 2012 Share Posted December 30, 2012 PM SMD Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted December 30, 2012 Share Posted December 30, 2012 PM SMD "Has horn, can travel" Quote Link to comment Share on other sites More sharing options...
4RE Leather Posted December 30, 2012 Share Posted December 30, 2012 thanks chris il take a look at that maybe i can earth it somehow and see if that works...... pete !! yeah was hoping i wouldnt have to reverse but looks like i will now, that wheel is yours just wanted to try all options before i let it go and stuck with no horn at all! Il shall take look at next few days weather and ring you Thanks guys why do i always find the problems no one ever comes across There are a few things we can try and have a volt metre. It may be that the Green ground wire that goes onto the spade switch on the base plate need not be there? If it was working b4 without wires by putting that on could effect it. Like I said all the equipment is here and if anyone wants to add then please do. Quote Link to comment Share on other sites More sharing options...
4RE Leather Posted December 30, 2012 Share Posted December 30, 2012 thanks chris il take a look at that maybe i can earth it somehow and see if that works...... pete !! yeah was hoping i wouldnt have to reverse but looks like i will now, that wheel is yours just wanted to try all options before i let it go and stuck with no horn at all! Il shall take look at next few days weather and ring you Thanks guys why do i always find the problems no one ever comes across thanks chris il take a look at that maybe i can earth it somehow and see if that works...... pete !! yeah was hoping i wouldnt have to reverse but looks like i will now, that wheel is yours just wanted to try all options before i let it go and stuck with no horn at all! Il shall take look at next few days weather and ring you Thanks guys why do i always find the problems no one ever comes across You did of course try the fues Darryl Quote Link to comment Share on other sites More sharing options...
4RE Leather Posted December 30, 2012 Share Posted December 30, 2012 I dont know what happend to the above post but someone edit it for me please, it won't let me! Quote Link to comment Share on other sites More sharing options...
jumping350 Posted December 30, 2012 Author Share Posted December 30, 2012 errr actually no i didnt il dig around in a bit and have a look is it the panel in the drivers footwell?? Quote Link to comment Share on other sites More sharing options...
scubapics Posted December 30, 2012 Share Posted December 30, 2012 The green wire is indeed an ground connection but it is for the horn relay. Thus you have a relay to investigate too. I'll post up the wiring diagram later when I find it. Quote Link to comment Share on other sites More sharing options...
4RE Leather Posted December 30, 2012 Share Posted December 30, 2012 (edited) The green wire is indeed an ground connection but it is for the horn relay. Thus you have a relay to investigate too. I'll post up the wiring diagram later when I find it. The wheel thats on there is a OEM swap. He had the 3 button configuration on there b4 but never used it. As you know the wiring comes off the centre plates into a conector and and clips in the loom. The green earth that is also part of the button configuration goes to the small spade switch on the left/ I recon this is the problem as by taking out the 3 button left centre plate and replacing it with a blanking plate there are no wires. hence there is no green wire going to the spade switch. I would say this is almost certainly the problem and one that was overlooked by myself when I changed the wheel and Darral when he fitted it. It needs an earth lol. I will let you explain how to do that one lol Edited December 30, 2012 by 4RE Leather Quote Link to comment Share on other sites More sharing options...
scubapics Posted December 30, 2012 Share Posted December 30, 2012 Serves me right for not reading properly! Could he reuse the connector, remove all wires except for the green one and plug it back in? I assume the clock spring is still attached. Quote Link to comment Share on other sites More sharing options...
jumping350 Posted December 31, 2012 Author Share Posted December 31, 2012 i was thinking that scuba whether i could just unclip the wires for the buttons recconect plug and put spade back on wheel and fire the horn..looks like i will have to take both wheels apart and sort it out that way or if can find some second hand buttons can butcher them instead Quote Link to comment Share on other sites More sharing options...
scubapics Posted December 31, 2012 Share Posted December 31, 2012 If you have the original wheel then it is easy to remove the buttons with the cable intact. Plug it in and try it out. If it works, maybe you can cut off all but the horn ground wire and then reuse the connector in your setup. Quote Link to comment Share on other sites More sharing options...
