fan blowing teaser
thirdearl
heres one for ya.as most of you will know my z fell out with a large tree.now every time you start engine,or have ig on,interior fans blow full chat,you cant stop them ,alter them,or direct them.
anyone know, (other than in some form of default mode) how to cure this.
cheers :teeth:
Haven’t looked at a circuit diagram but to hazard a guess. I think the ignition switch enables all of the cars auxiliary ccts, ie allows you to turn some ccts on only when the ignition's on. The fan must still have either a short cct to some other auxiliary live connection or some device in the fan cct is still broken keeping the cct permanently live.
Not much help I know but check out the wiring around where the car was damaged and look for signs of insulation damage or connections shorting out. A good guy with a cct diagram and a multimeter should be able to sort that one fairly easily as the faults always on. It’s the intermittent ones that are the buggers.
