Dblock Posted December 25, 2012 Share Posted December 25, 2012 So I'm sure some of you know I've been looking for a JOBD/JDM code reader for a while since my OBD2 reader wouldnt work. Now I looked into blazt and cipher but they are a lil expensive ( although very good and you can do alot of stuff with them). I'm sure a few of you with JDM's have been looking for a code reader that works for a while, rather than doing the pedal dance. :wink: Soooo, after Rich saying that some lambda codes could be stored which is true ( my other obd reader for the clio plugs into laptop and tells you such things) I thought I have got to get a code reader. So took a plunge on EBAY ! I wasn't really expecting it to work after many people saying unless you spend alot nothing reads JOBD. The one I got says JOBD on it so I thought well it must do it. Came from Hong Kong took about 2 weeks to arrive. Plugged it in nothing. Crap. Read the manual . Plugged it in again scrolled down to Nissan and press enter... Reading codes... IT WORKS!!!!! :yahoo:I do have a code p0550 but that has been there for a while so its alright So I bought the super expensive reader for the massive sum of I hope your sitting down as if you look up it costs £0000's to read JDM codes... £27.39 Here is the link for it http://www.ebay.co.uk/itm/380503945578?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649 So JDM code reading is just as easy as UK now and just as cheap. 1 Quote Link to comment Share on other sites More sharing options...
saihaynes Posted December 25, 2012 Share Posted December 25, 2012 Good to know dude, I use both blatz and a variation edudatascan, I've ordered one to test on the 350gt but supports JOBD so should be fine Quote Link to comment Share on other sites More sharing options...
glrnet Posted December 25, 2012 Share Posted December 25, 2012 Good find mate Quote Link to comment Share on other sites More sharing options...
evilscorp Posted December 25, 2012 Share Posted December 25, 2012 Nice find! 'Off to ebay he goes' Quote Link to comment Share on other sites More sharing options...
gillywig2 Posted December 25, 2012 Share Posted December 25, 2012 Looks good. When it says it clears codes, does that mean it can also reset the ecu? Quote Link to comment Share on other sites More sharing options...
saihaynes Posted December 25, 2012 Share Posted December 25, 2012 Looks good.When it says it clears codes, does that mean it can also reset the ecu? i Hey gilly, No it will read and where applicable reset the code generated........ You can reset the ecu on the 350gt via the pedal method (similar to the 350z) or by disconnecting the battery overnight Sai Quote Link to comment Share on other sites More sharing options...
gillywig2 Posted December 25, 2012 Share Posted December 25, 2012 Ok, thanks Sai. Quote Link to comment Share on other sites More sharing options...
JohnUKVetteNut Posted January 1, 2013 Share Posted January 1, 2013 hi looked up the ebay item and its listed at 127 not 27 as stated..did i miss something here? cheers johnukvettenut Quote Link to comment Share on other sites More sharing options...
Dblock Posted January 1, 2013 Author Share Posted January 1, 2013 hi looked up the ebay item and its listed at 127 not 27 as stated..did i miss something here? cheers johnukvettenut Hmm they are probably out of stock. When I'm on the pc il send you a link. Quote Link to comment Share on other sites More sharing options...
StevoD Posted January 1, 2013 Share Posted January 1, 2013 i got it for £27 on christmas day, Maybe because they have all of a sudden had a wave of demand for them Quote Link to comment Share on other sites More sharing options...
Dblock Posted January 1, 2013 Author Share Posted January 1, 2013 here is one for £31 http://www.ebay.co.uk/itm/OBDMATE-OM500-Scan-Tool-OBD-II-JOBD-Code-Reader-/160918631423?pt=UK_Diagnostic_Tools_Equipment&hash=item25777f73ff Quote Link to comment Share on other sites More sharing options...
JohnUKVetteNut Posted January 2, 2013 Share Posted January 2, 2013 Hi thanks for updated ebay...just ordered one!! Thanks JohnUKVetteNut Quote Link to comment Share on other sites More sharing options...
