Advice on getting rear wheel alignment
mrchic
Hi
I was getting a puncture repaired last week on my passenger rear tyre, and whilst there asked the technician to look at the drivers rear tyre as i knew there was 0mm on the inside.
he said it looked like it was leaning. I'm hoping this is some sort of camber and needs checking adjusting.
ideally i would do this before buying new tyres?
I was also told the alignment is a specialist job, do i need to to Nissan
cheers all
Merry Xmas
To add there is aset way of doing them and often a bog standard tyre place does not know this.
I know of 2 places one being Abbey (who put the correct way up on here)
And failing that RSR Tyres at Old Coulsdon who have the latest Hunter Machine.
For good old fashioned know how I would go to Abbey:
Have you got a link to the page where Abbey says the correct way of doing it? I had mine done by ETS a while back when I got MPSS fitted and the handling and grip has never felt as good as before I went to them.
There's no set way of doing it as such, but each car should be adjusted to how the driver wants it to feel which will be inside a particular envelope of settings for a given vehicle. Any place can get the wheels pointing straight, but usually the experts such as Abbey can understand that a Zed might feel better with more camber or toe at a particular point on the car.
:blush:
Edited by 4RE Leather
Hello fellow Essex person! I live in Milton Keynes now,and over the road from where I live is a place called Atomic Wheels and tyres. Its an hour from where you are. Taken my Zed there a couple of times for various bits, including laser alignment, and cant fault them. They have the latest Hunter equipment and know how to use it. Just off junction 14 of the M1.
Very knowledgable guys, (and a hot receptionist), and although they are not specialists in Zeds, they know their stuff, and always very friendly. Maybe abit closer to you than Abbey.
I took my MX-5 there, very knowledgeable chaps and would use them again. Have also used DMS at Erith too, once again excellent.
