FAQ: What issues are there with the phone kit?
Removed
The phone kit has some problems with interference for certain phone models (principally the Nokia 6310i). Nissan have now recognized a fix pioneered by 350zuk.com forum member Peter and will carry this out if you have a problem with your kit. It is generally successful.
Some people have found that the phone kit does not work well for them (it won?t respond correctly to voice commands or reception is not acceptable), whilst others are happy.
The kit requires you to programme each number you want to dial. It will not use your existing voice commands on your phone.
If you do need to use your phone in your car the phone kit may provide a very convenient solution because of the steering wheel controls and because it is already mostly installed.
