wls350 Posted December 20, 2012 Share Posted December 20, 2012 (edited) Ok so first of i had this damaged drivers air vent in my car, i went to Nissan and they wanted a ridiculous amount of money for it, so i got a brain wave and figured ill get a Wide Band AFR , since im going to Nos and turbo later. I got an Innovate Red LCD DB series Gauge with a LC1 Bosch sensor. I took a good long look at this whole thing and figured it would be fairly easy, turned out to be far from. Below are some pics of the install and a video clip of it in action. (i went for a red one as i have ordered the red LED Guages from Blacktop custom guages.) This is what my door vent looked like, dont even ask as i dont even know. Removing door panel was relatively easy work, a few clips and it pops out. I had to cut the vent out of the guage, only to realise that you could in fact unclip it from the back DUOH ! Little Pre Check to see the gauge would fit.. While i had everything out, i decided to sand and respray the lot, using plain flat black spray paint. After first sand and spray the handle was quite badly scratched so i decided to wrap it in red carbon wrap. In order to get it to fit we decided to mod the stock housing of the air vent to keep the stock look Once it fitted flush, i tacked it in with some pratly putty, and glued the vent back into place where i broke it of. wrapped it and fitted door panel back together. End result is it really came out very well in my opinion. I had the Bung welded into the exhaust right after the 3 joined into one. and ran the connector up next to the gearbox housing. i ran it through the drivers side compartment where the brake fluid ect lies. went through the firewall and into the car. wiring i just wired up as per instruction and calibrated it. I know have a full wideband guage which is really handy as i can log data with it aswell. http://www.youtube.com/watch?v=ujQdhiD36Go&feature=youtu.be http://www.youtube.com/watch?v=1GDvhDClWAI&feature=youtu.be Edited December 21, 2012 by wls350 Quote Link to comment Share on other sites More sharing options...
4RE Leather Posted December 20, 2012 Share Posted December 20, 2012 That looks cool:) Quote Link to comment Share on other sites More sharing options...
Wasso Posted December 20, 2012 Share Posted December 20, 2012 (edited) That looks cool:) Do it Peter! (Now time to work out which smiley works :smile: ) Oops forgot to say - looks nice Edited December 20, 2012 by Wasso Quote Link to comment Share on other sites More sharing options...
4RE Leather Posted December 20, 2012 Share Posted December 20, 2012 That looks cool:) Do it Peter! (Now time to work out which smiley works :smile: ) Oops forgot to say - looks nice It would be quicker to walk to yours for a cuppa Ian. Quote Link to comment Share on other sites More sharing options...
andy james Posted December 20, 2012 Share Posted December 20, 2012 Bloody Hell that looks well good! Quote Link to comment Share on other sites More sharing options...
sparky370z Posted December 20, 2012 Share Posted December 20, 2012 What does it measure. What's the point of it???? Quote Link to comment Share on other sites More sharing options...
Ian Posted December 20, 2012 Share Posted December 20, 2012 Good work. I've been telling Andlid for years to put a gauge in the vent Quote Link to comment Share on other sites More sharing options...
Keyser Posted December 20, 2012 Share Posted December 20, 2012 What does it measure. What's the point of it???? AFR - Air Fuel Ratio and 14 is a good number 13.7 is optimum (well on mine) Nice work OP Quote Link to comment Share on other sites More sharing options...
wls350 Posted December 20, 2012 Author Share Posted December 20, 2012 What does it measure. What's the point of it???? AFR - Air Fuel Ratio and 14 is a good number 13.7 is optimum (well on mine) Thanks man, in the pic it was on idle It will idle ar Round 14.7 here at altitude. Wode open throttle im running very very rich, 10,9 to 11.1 ish, so there is loads of power to come, i am aimimg for 13,3 under full tap. With nos i will be able to run a dif map little richer 12.2 u would think. Nice work OP Sent from my GT-I9300 using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
Dblock Posted December 20, 2012 Share Posted December 20, 2012 cool Quote Link to comment Share on other sites More sharing options...
DoogyRev Posted December 21, 2012 Share Posted December 21, 2012 Looks great Nicely done Quote Link to comment Share on other sites More sharing options...
evilscorp Posted December 21, 2012 Share Posted December 21, 2012 Nice work got A/F of 14ish too. Quote Link to comment Share on other sites More sharing options...
