x20drb Posted December 11, 2012 Share Posted December 11, 2012 Hi guys, did a quick search but couldn't find anything conclusive, Planning on doing the bose hack at the weekend, but i want to put a power source in for my iphone at the same time, so i have an aux and apple lightning connector both in the cubby hole, how can i wire an iphone 5 cable into somewhere behind the headunit with switchable power? i have a 12v to usb adaptor? could that be a way to do it, but how do i wire the 12v plug into the battery somewhere? Any advice would be great, cheers in advance for your help! Dan Quote Link to comment Share on other sites More sharing options...
JackStrong Posted December 12, 2012 Share Posted December 12, 2012 Hi Dan Well for a start find a wiring diagram for the lightniing cable. I would also check the amperage required for the iphone to charge as I once had a 12v usb connector which i plugged the iphone cable into it and the amps were half what it needed to be. I did the bose hack a few months ago. I have a 4s and wired in an iphone connector to the bose. Maybe you could do the same with the 5 Quote Link to comment Share on other sites More sharing options...
