Engine light came on
Toad
Grrr just noticed the Engine Light yellow one has come on - can't seem to get the reset to work, the engine sounds fine but obviously its a bit of a concern - anyone advise what i could do - is it best to go to a nissan dealer or will a local garage be good enough ? Sorry sure this has been asked loads of times before
i'm in wotton under edge - 20 miles north of Bristol up the M5 - its the yellow Malfunction Indicator - apparently if its flashing it's bad but if it's on solid (which it is then its drivable), means an engine control system malfunction
Edited by Toad
this the one I bought, you can't go wrong for that price.
http://www.amazon.co...54812068&sr=8-3
Did it work?
I had it read by a garage when it was in the post, so didn't have chance to try it, but I did plug it in when it arrived, and it was recognized by the car, so there should no problem if or when the lamp appears again.
I also plugged it into the works vehicle, and even it told me the VIN number
