JetSet Posted December 6, 2012 Share Posted December 6, 2012 So what you keep the bottle in the car? so what happens when the doors freeze shut? +1 had this happen last night -4 at 3:30am leaving work well i would leave if i could get in the car This is a problem that seems specific to the Zed. I've had loads of cars and never had a car door freeze solid before. The Zed freezes up far too easily. Pete Quote Link to comment Share on other sites More sharing options...
ChrisS Posted December 6, 2012 Share Posted December 6, 2012 So what you keep the bottle in the car? so what happens when the doors freeze shut? +1 had this happen last night -4 at 3:30am leaving work well i would leave if i could get in the car This is a problem that seems specific to the Zed. I've had loads of cars and never had a car door freeze solid before. The Zed freezes up far too easily. Pete Time to Gummi Pfledge them seals Pete. (or drive over here for breaky and I'll lend you some) But it's probably cheaper to buy some. http://www.perfectly...tick-1242-p.asp Quote Link to comment Share on other sites More sharing options...
ddcboyle Posted December 6, 2012 Share Posted December 6, 2012 +1 incase ur lazy like me and forget to put anti freeze in the window washer fluid. Bottle of water over the windscreen and clears the journey up. Otherwise youll be sticking behind a lorry letting slush wash ur windows. Quote Link to comment Share on other sites More sharing options...
Chris`I Posted December 6, 2012 Share Posted December 6, 2012 Time to Gummi Pfledge them seals Pete. (or drive over here for breaky and I'll lend you some) But it's probably cheaper to buy some. http://www.perfectly...tick-1242-p.asp Yup, I was out doing the van a few weekends ago. Fair bit more rubber than the Zed, but works a treat. I also find on the Zed that the window guide/seal (flocked bit at the bottom of the window) would stick on the 350z. When this happens and you have no luke warm water, just use a credit card to slide along and break the bond to the window and it will drop as normal Quote Link to comment Share on other sites More sharing options...
Leeroy Posted December 6, 2012 Share Posted December 6, 2012 I find rubbing my face on the windscreen helps, if it's really frosty I normally just rub a stripe off at the height that my eyes will be looking out. Window licker I wouldn't want to mislead potential face wipers SMD, I don't lick the ice off. I use my CHEEK. I did try licking the ice off but my tongue got stuck to the windscreen and I spent the morning stuck to the car and was late to work. 1 Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted December 6, 2012 Share Posted December 6, 2012 I find rubbing my face on the windscreen helps, if it's really frosty I normally just rub a stripe off at the height that my eyes will be looking out. Window licker I wouldn't want to mislead potential face wipers SMD, I don't lick the ice off. I use my CHEEK. I did try licking the ice off but my tongue got stuck to the windscreen and I spent the morning stuck to the car and was late to work. Glad you sorted that one out for us, wouldn't want you looking silly or anything Quote Link to comment Share on other sites More sharing options...
DaddyCee Posted December 8, 2012 Share Posted December 8, 2012 don't spray copious amounts of de-icer, just a little spray and a cloth (jeyes cloth is what I use) and then wipe the residual fluid over all your windows and it doesn't leave any gunk on the screen and works very quick. Front heated screen seems to warm up quite quick, but nowhere as quick as my old Ford Puma did. Quote Link to comment Share on other sites More sharing options...
