AMT Posted November 26, 2012 Share Posted November 26, 2012 For all the chatter that goes on here about higher octane etc, found this vid when watching sum others at lunch. Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted November 26, 2012 Share Posted November 26, 2012 Remember watching this on the telly.... I'm not convinced paying the extra is worth it either in performance or extra MPG but plenty are so fair enough Quote Link to comment Share on other sites More sharing options...
Dblock Posted November 26, 2012 Share Posted November 26, 2012 Ancient test. 5th gear recently did it agai showing on the right cars (cars where ecu knows to make use of better fuel) all made more power. Cocky said it was noticeable? I have personally found that with my 172 but makes no difference in my mums merc. I got slight better mpg and slight more power. It felt faster and more torquey. Quote Link to comment Share on other sites More sharing options...
DannyBoy Posted November 26, 2012 Share Posted November 26, 2012 Is this not sort of a moot point with the zed? Numerous tuners have stated and proven that the zed WILL run on an anti-det map if you run it on regular unleaded. Putting aside all the speculative 'this will destroy your engine' stuff, I think it goes without saying that running on an anti-det map is not going to make as much power as running on the normal map on the correct fuel. DB Quote Link to comment Share on other sites More sharing options...
