USB OBD-II Interface
Rob_Quads
This auction is for an ODB-II interface compatible with the 350z.
What exactly can you do with this ISO-Protocol Interface and the Software?
In general, this interface, together with a computer and software making a powerful and flexible scanning tool at home. With ScanTool.net or software like this, the interface can work with all vehicles (without CAN-Bus) regardless of their makes as long as they are newer than model year 1996 in the USA. In European since 2001, diesel cars later. As a typical example, it lets you perform the following operations:
· Read diagnostic trouble codes, both generic and manufacturer-specific, and display their meaning (over 3000 generic code definitions in the database).
· Clear trouble codes and turn off the MIL ("Check Engine" light)
· Display current sensor data, including:
o Engine RPM
o Calculated Load Value
o Coolant Temperature
o Fuel System Status
o Vehicle Speed
o Short Term Fuel Trim
o Long Term Fuel Trim
o Intake Manifold Pressure
o Timing Advance
o Intake Air Temperature
o Air Flow Rate
o Absolute Throttle Position
o Oxygen sensor voltages/associated short term fuel trims
o Fuel System status
o Fuel Pressure
o And many others...
What are PC requirements?
You must have Microsoft Windows 98/ME/2000/XP with Microsoft Internet Explorer 5.01 or later installed on your computer.
Minimum PC hardware requirement:
· Pentium 200MHz or faster
· 64MB of RAM or more
· CD-ROM or DVD-ROM Driver
· USB Port
What European vehicles?
For European emission related standards, EOBD starting in year 2001 is the equivalent of OBD2 in the USA.
PRICE: £35 Delivered
Guest prescience
Rob,
Have you used this successfully with the Z - only the Z has a CAN-BUS system.
Also, I am not sure what CAN protocol the car runs but I do recall that someone had tried one of these type of readers with different standard protocols on the Z without being able to read any parameters successfully. I'll try and find that info. but the guy who was trying it seemed to know his stuff.
Not trying to p*ss on your chips - I'm sure you've used it successfully :teeth:
Yes I have used this on my 350z. I can get some pictures & video if you want.
I think you are getting mixed up in terminology. The CAN-BUS is the type of network the cars use, ISO is the specific protocol that the 350z and many other cars use.
Guest prescience
No, I (think I) understand it but didn't explain it - I believe there are different protocols used by different manufacturers on OBD-II, not just one?
Anyway, it sounds like it's all good - hope you didn't mind me asking :D
