rickoshay Posted November 21, 2012 Share Posted November 21, 2012 Hi I am thinking of replacing the windscreen as it has lots of little chips, possibly as the result of a gritter lorry. Its unlikely that Swift cover will replace it as its not illegal. I have contacted windscreensonline and they have quoted £259 to supply and fit, after I confirmed that it is not a screen with a built in aerial ( since the aerial is on on the back of the car )- they had advised that there are 2 versions, one of which is near £1,000. Autoglass quoted over £700 for a standard windscreen!! I assume Autoglass must use Nissan parts whereas windscreensonline use OEM parts. I am a bit worried about going for the low quote in case of problems with the windscreen,or bad fitting. I am wondering whether its worth the risk!! I also understand that the windscreen trim is a bit delicate. Its just that the small chips create a few problems when driving into a low sun. I tried glass polish but that did not help! Any helpful thoughts appreciated! Quote Link to comment Share on other sites More sharing options...
Ekona Posted November 21, 2012 Share Posted November 21, 2012 I would suggest that it could be cheaper to replace if there was a lovely crack in it, right in the driver's eyeline that could not be repaired IYSWIM. Then it would go via the insurer and you'd only pay your excess. £259 seems miles too cheap for a screen, but if it fits then it fits. Given the alternatives, I'd take a punt for that price. Quote Link to comment Share on other sites More sharing options...
kamamakazii Posted November 22, 2012 Share Posted November 22, 2012 I agree best suggestion is to "wait" untill there is a crack that would be covered by your insurance. Quote Link to comment Share on other sites More sharing options...
ddcboyle Posted November 22, 2012 Share Posted November 22, 2012 Probably no use replacing it for chips unless its cracked. I can see why you want to, once the glass is polished they all stand out. But its money fixing something thats not really broken Quote Link to comment Share on other sites More sharing options...
