garygttdi Posted November 20, 2012 Share Posted November 20, 2012 Heavily modified 350 GT (Abbey) been told car is running rich, certainly exhaust would back this up as like others I clean it and with minutes it’s black again. Could this be the MAF if so can they be cleaned adjusted or should I just get a new one and get it fitted, Zamalex maybe? Quote Link to comment Share on other sites More sharing options...
Mark@Abbey m/s Posted November 23, 2012 Share Posted November 23, 2012 (edited) How do you know it is definitely running rich other than black tail pipes? When you say heavily modified 350GT trying to think of a big build we have done on a 350GT , except a S/C tune 3 or so years ago. just found out what car you now own, 350Z GT model, Could be AFM but this will normally cause a CEL to be thrown up. Also could be a pre cat lambda sensor going open circuit. This car is tuned for power so it will blacken the tail pipes. Edited November 23, 2012 by Mark@Abbey m/s Quote Link to comment Share on other sites More sharing options...
Dblock Posted November 24, 2012 Share Posted November 24, 2012 Would a pre cat lambda cause a CEL or not always? Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted November 24, 2012 Share Posted November 24, 2012 no it wouldn't, but you might find its stored a code on the ECU, first thing i'd do is get a code reader on it. not all issues flash a CEL light on. Quote Link to comment Share on other sites More sharing options...
Dblock Posted November 24, 2012 Share Posted November 24, 2012 no it wouldn't, but you might find its stored a code on the ECU, first thing i'd do is get a code reader on it. not all issues flash a CEL light on. Good to know cheers. Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted November 24, 2012 Share Posted November 24, 2012 my jag didn't on both the pre cat H02 sensors, but both had codes stored on the ECU when read. no light no nothing, only noticed as i track my fuel mpg on an app. Quote Link to comment Share on other sites More sharing options...
garygttdi Posted December 3, 2012 Author Share Posted December 3, 2012 Hi Mark et-all, Yes you are correct it’s the car that you guys rebuilt the engine on from the crank up. It’s now living down in the West Country down in Devon so bringing it up to you guys would be a hike. Took the car to Alan Jeffries “The engine Tuner†down in Plymouth. He was full of praise for the car although a Subaru man really, he just commented that it appeared to running a bit rich. Personally I find its fine, so think I will leave it alone no warning lights etc. Would love to talk to you guys about supercharging just not certain I can justify the £6-7 K price tag or am I coming up sort even on those numbers ? Thanks for replies guys. Quote Link to comment Share on other sites More sharing options...
Mark@Abbey m/s Posted December 4, 2012 Share Posted December 4, 2012 So it hasn't been run on a dyno top read the AFR just a comment from someone. As I said we run that car a little rich top end for power/torque. Yes I am afraid S/C is still the same sort of £'s and that car you have has very high compression ratio so it doesnt really lend itself to F/I I am afraid, I can be done but the gains wont be as good as a stock compression ratio car fitted with a S/C. Quote Link to comment Share on other sites More sharing options...
Keyser Posted December 4, 2012 Share Posted December 4, 2012 Come on Mark - Stick some water meth in it as well he will get great results Hi Comp low boost FTW Quote Link to comment Share on other sites More sharing options...
Mark@Abbey m/s Posted December 4, 2012 Share Posted December 4, 2012 (edited) water meth runs out....not a lover of water/meth injection never seen results that people say they get when running it on my dyno. But there again change the ECU to Syvecs and then we can talk.... Edited December 4, 2012 by Mark@Abbey m/s Quote Link to comment Share on other sites More sharing options...
Jez @ H-Dev Posted December 4, 2012 Share Posted December 4, 2012 (edited) Same here - tried water injection, still use Syvecs. Syvecs wins Edited December 4, 2012 by Jez Quote Link to comment Share on other sites More sharing options...
