RareJDM engine cover
smudgedon
How the feck does this fit?!
The instructions that are included have poor quality pics and don't really say what to do either
I've removed the OEM cover and tried to rearrange the cables etc underneath, but for the life of me can't see how the RareJDM cover fits
Any help appreciated :)
Once you take the engine cover off, there are 2 studs sticking out. Remove the 2 studs & fit the harness cover in place & fit the new screws into where the studs were extracted from :)
Dead easy to fit apart from getting those 2 studs out
See I found the studs easy with a bit of trickery.
My issue was doing up the nuts behind where the screw replaces the studs.
Here's the two nut trick....
Tighten nuts onto the stud and use the lower one to remove the stud with a spanner.
Edited by Wasso
