Brake pads clip
shieldsie
Why or what is the purpose for the small clips sticking out on the pads for? The back pads all have the clips attached, but the fronts only on 2 of the 4? Does it make a difference ahich side the fronts go in? Does the one with the clip supposed to go on the inner side / outer side, or doesnt matter?
I'll guess (a pic would be good) wear sensor's - normally fitted to the inside of the caliper - if you have the warning sensor they should clip onto a wire.
But I don't have them - but I haven't seen clips on any 350 brake pads yet :wacko:
