Help - bleeding brakes!
Whazza22
Hi all,
My brake pedal has been a bit spongy for a week or so since the brake pads were inspected.
I have followed the brake bleeding procedure to remove the air in the system but it won't clear.
Tried both the rear brakes with the tube and jar method but quite alot of bubbles still keep coming out!
Have gone through 2 litres of fluid and its not getting any better.
Any ideas?
Thanks
Jar with bit of new fluid in and a length of rubber hose.
Pumping the brake several times and bleeding each brake. Sequence should be right rear, left rear, right front then left front until bubbles stop.
However, after doing it about 15 times on the first brake and still loads of bubbles I'm stuck :(
